Myford S7b Gearbox Mod
Home Forums Manual machine tools Myford S7b Gearbox Mod
  • #80365
    Peter Wood 5
      @peterwood5
      At the recent Model Engineer Exhibition I had a brief conversation with a gentleman on the SMEE stand, demonstrating screw cutting. I believe he was Derek Brown and he showed me the modification to his Myford gearbox to allow a quick change of the gears to convert an Imperial machine to metric.
      I am sure he told me that an article on the mod had been published ‘last summer’ (2010?) and that the castings were available.
      Can anybody tell me which edition of ME or MEW it was in or contact details pls?
      And Merry Christmas to all readers!
      Peter
      Peter Wood 5
        @peterwood5
        #80374
        Gray62
          @gray62
          Issue 177 of MEW has an article by Derek on this mod which is titled Metric Screwcutting without tears on the Myford
          Merry Christmas
          Graeme
          Edited By CoalBurner on 24/12/2011 10:38:24
          #80380
          John Stevenson 1
            @johnstevenson1
            You can also do the same with what you have and far less hassle by just replacing the 24 tooth driving gear with a 33 tooth or 34 tooth.
            Ten minutes work max.
            John S.
            #80381
            KWIL
              @kwil
              It is all a matter of how close in terms of pitch accuracy and range of threads you want/need. Read the article and then compare it with JS’s quick fix. I have the DAG Brown set up on my Super 7 and I am very satisfied.
              #80395
              Peter Wood 5
                @peterwood5
                Thanks for the info CoalBurner. I will take KWIL’s advice and read the article before making any decisions.
                I avoided screwcutting on my little 7 x 10 even abandoning a Hemingway kit which needed internal and external threads. But now having just acquired an S7b and watched DAG I now feel confident enough to have a go.
                Peter
                #80397
                Sub Mandrel
                  @submandrel
                  Hi Peter,
                  Have no fear about screwcutting on a 7×10. I have cut threads up to 1 1/2″ diameter and in abroad range of metric and imperial sizes on mine.
