Ok, I bang on here, I know, I'm just outlining what I have already (hopefully) understood and read on other threads, I don't think I actually ask much of question on this thread, I'm just looking for comments/reassurance I think?
If you can find 5 minutes for a little head scratch please grab a cup of tea, thanks in advance, and here goes!
Well, I thought the Myford I bought was in superb condition but I'm seeing conflicting info, the front and rear shears deviate a minimal amount in width and thickness from factory standard, and the carriage travels just by pushing it forwards and backwards the full length of the bed – ever so slightly tighter near the tailstock but oddly the apron fouls the leadscrew bearing block – too close but beautifully even, free and smooth – with my DTI clamped to the bed and resting on the front edge of the cross slide about 4" from the lathes centreline and with one hand grabbing the front of the cross slide, one on the back bearing down and twisting left/right with very firm force I get no more than 0.11mm of movement on the needle, locking the carriage reduces this to 0.7mm and moving towards the tighter end and locking reduces unclamped movement to 0.8mm – its pretty dam smooth, consistent and deflection free IMO despite being so free to glide about – I could reduce this figure as I can feel some rocking in the crossslide but its minimal – I don't have to time to go over the adjusting procedure again but I could get it better
I have set up the carriage gib by adjusting the first 3 screws which bear on the short inner hidden fast side (fast side bears on the inside face of the front shear, ie narrow guide) first by adjusting the outer 2, then bringing the centre in snug, and then finally adjusting the 4th one at the tailstock end gently so as not to twist the carriage or wear the corner off the fast side at the tailstock end.
Now I did notice when checking for the common "twist" on these narrow guide Myfords that the gap between the rear face of the rear shear and the carriage was slightly uneven from left to right but almost spot on, Further researching and reading Nigel B's comments in the thread "Lathe Turns Convex" and following various links here and there – points towards the general consensus that this gap should measure 0.0625" (1/16th" or 1.5875mm)
Measuring in metric, but talking in imperial for consistency with the community and past threads, I have a gap of just 0.014" aka 0.35mm on my metric gauges (headstock end) and 0.010" – 0.025mm tailstock end. this gives me 0.004" – 0.1mm deviation which I feel is exceptionally low/evenly worn, could anyone confirm this?
Now if the gap is supposed to be 1/16th – I'm obviously a very long way off – indicating that what appears to me (a novice) to be an exceptionally good condition, low wear machine and "straight" machine is actually very very worn albeit evenly?! this explains why my apron fouls the leadscrew bearing block at the tailstock end – I thought this was uncharacteristic of the general design and build quality but cracked on as it was all so nice and smooth……..
I'm just a bit confused, I don't have any large diameter stock or a faceplate to run a DTI on, I do have a very nice surface plate and a 150mm length of 75×12 mild steel flat bar – I'll grab that in the 4 jaw if I can, and give it a skim but I expect it to turn nicely given the carriage gaps described above and hopefully slightly concave – blue on the surface plate will be the test and given its long and thin I can probably slip a feeler gauge under it in the middle and quantify something – maybe
Has anyone seen a machine "this" worn before? – I'm thinking perhaps it was converted to wide guide and the 1/16th strip has fell out, or perhaps someone has scraped/corrected the fast side and took a to much out of it…….. I don't know – but now after gib adjustments its running better than it ever has….. happy and worried at the same time!
Thanks for reading – what a long thread…….
Edited By Russ B on 09/09/2014 12:53:54
