Hi Dennis,
Many thanks for the in-depth information on the early box. I did not think it was going to be easy !! The lathe was picked up from an estate sale by the previous owners son. There is a slim chance that some of the missing parts are still at the same address so I am taking steps to check on that, now that I have a better idea what is not actually here !!
My lead screw is full length at the moment, but at some time in the past it looks like it was fitted to an early box, as now there is a thicker tube portion that might have been welded/brazed on to take it back to standard length. It can not have been used on my lathe with a box ,as there are no holes drilled and tapped on the side of the bed for the box fitting.
While on that subject point, I would like to drill the box fixing holes while the machine is stripped down. Does anyone have a drawing for the position of them ?
One part of the box I can't yet figure out. The smallest gear on the internal cluster is a 16 teeth gear. There is a cross hole in the shaft where this gear should be. Is this for lubrication , or is that single gear pinned? All the others are secured by a long key and they are all here. If you could explain how the drive is taken from the cluster gear shaft to the layshaft and also the purpose of the dog clutch, I will then have all the facts. (I hope !!)
One last question, should there be a ball and spring under the top cover to act as a detent for the quadrant. ? The small grub screw is present but no detent here.
Mike.
