Myford ML10 lives again
Home Forums Workshop Tools and Tooling Myford ML10 lives again
  • #404692
    Dave Springate
      @davespringate
      Well at long last it's finished and running again. I'm really pleased with it and have enjoyed the strip and clean up. I had a problem with the electrics but thanks to the help and advice from a forum member David (AKA Myford boy) I got it sorted. Thanks again David !
      Dave Springate
        @davespringate
        #404800
        Dave Springate
          @davespringate
          #404812
          not done it yet
            @notdoneityet
            You will only need the reverse for running off-load – unless you have some means of preventing the chuck from unscrewing!smiley
            #404820
            Mick B1
              @mickb1
              Posted by not done it yet on 12/04/2019 21:00:32:
              If the chuck's done up tight, you need quite considerable resistance to make it unscrew. I used to sand and polish wood quite heavily in reverse as well as forward on the Speed 10 I had, without ever having that happen. It's also sometimes easier to get a knife tool at an angle to the the far side of a workpiece and chamfer the face in reverse.
              Probably not heavy screwcutting, though… laugh
              #404821
              Emgee
                @emgee
                Hi Dave, nice job you did there.
                Couldn't see any remote Stop in case you get caught up in the chuck or belt, perhaps it's at knee height ?
                Emgee
                #404827
                Former Member
                  @formermember32069
                  #404860
                  Dave Springate
                    @davespringate
                    Posted by Emgee on 12/04/2019 22:52:33:
                    Emgee
                    Hi Emgee, Yes a bit of an oversight on my part, I have no tooling for the lathe yet and would like a quick change toolpost so while I save some pennies for these items I have ordered an emergency stop button and will fix to the front of the bench before I start to use the Lathe.
