Hi Carl,
My first question is. What are you refering to as "a miller" ?
Wikipedia defines it as "A miller usually refers to a person who operates a mill, a machine to grind a cereal crop to make flour.. I assume you are refering to a milling machine or mill. (sorry to be so picky)
I would chose the bigest, most rigid machine that you can accommodate in your workshop. Rigidity is the main feature you are looking for when buying a machine. Also ensure that there is enough height under the cutting tools to fit your project.
My first mill/drill was a Sieg SX3 which had a high torque brushless DC motor with variable speed control. It worked great for about a year (warranty period) but then started to have problem with the electronic motor controls. I now have an RF-45 clone, available under a lot of other names and is a bit bigger and more rigid. (the column on the Sieg would twist under heavy loads). This mill has an AC motor and a gearbox with steel gears and should last a bit longer than the SX3. My preference if I had the room in my workshop would be for a Bridgeport type machine with 3 phase inverter speed control. A tilting head in both axes is an advantage. Just remember too that tooling can cost as much as the mill.
Paul
Edited By Paul Lousick on 02/08/2017 07:00:50
