Posted by Joe falconer on 02/12/2018 19:04:26:
Hello,
i'm new to here and am slowly building up my workshop,
i'm after my first lathe, would you recommend a ML10?
Thank you
If you're going to build model engines, you might find it too small. I did. For example, many of the medium and larger Stuart kits have a 7" flywheel, which an ML10/Speed 10/Diamond 10 can't machine without serious mods, whereas the 7 Series can. If you want to do milling on it, the 10 Series cross slide is narrow, as is the bed dovetail, and that's very limiting.
I had a Speed 10 for 15 years. I'm not going to get into a brand names debate, but I'd seriously consider something a bit larger unless you're interested mostly in smaller work.
