MJ Morse taper
MJ Morse taper
Home Forums General Questions MJ Morse taper
  • #298638
    sean logie
      @seanlogie69385
      Can anyone inlighten me on tge difference between a mj morse taper 3 and just a mt 3. Are there different sizes of morse taper 3 ?
      Sean
      Edited By sean logie on 18/05/2017 10:01:16
      sean logie
        @seanlogie69385
        #298644
        Emgee
          @emgee
          Hi Sean, are you sure where you saw mj written it wasn't a typo ?
          Emgee
          edited spelling
          Edited By Emgee on 18/05/2017 10:27:19
          #298645
          David Standing 1
            @davidstanding1
            There are lots of machine tapers, but four similar ones with the same rate of taper are Morse, Jacobs, Jarno, and Brown & Sharpe.
            'Jarno' was the pen name of Oscar J. Beale, who in real life was basically the head of engineering at Brown & Sharpe in the late 19 th century.
            Despite this, Jarno and Brown & Sharpe tapers are not the same. Go figure!
            'MJ' might refer to a Jarno taper.
            Edited By David Standing 1 on 18/05/2017 10:36:20
            #298649
              I suspect that emgee is correct … but these tables might prove useful: **LINK**
              http://littlemachineshop.com/reference/tapers.php
                Might be best to measure the thing Sean. That will reveal if it's an ordinary MT3 or a weird special. Possibly 'MJ' is a maker's mark or other irrelevant stamping.
                As Michael suggested, from littlemachineshop.com, my bold:
                Taper Large End Small End Length Taper/
                Foot
                Taper/
                Inch
                Angle From Center
                #0 0.3561 0.2520 2.00 .6246 .0521 1.4908
                #1 0.4750 0.3690 2.13 .5986 .0499 1.4287
                #2 0.7000 0.5720 2.56 .5994 .0500 1.4307
                #3 0.9380 0.7780 3.19 .6024 .0502 1.4377
                #4 1.2310 1.0200 4.06 .6233 .0519 1.4876
                #4-1/2 1.5000 1.2660 4.50 .6240 .0520 1.4894
                #5 1.7480 1.4750 5.19 .6315 .0526 1.5073
                #6 2.4940 2.1160 7.25 .6257 .0521 1.4933
                #7 3.2700 2.7500 10.00 .6240 .0520 1.4894
                #298694
                Lambton
                  @lambton
                  David,
                  "There are lots of machine tapers, but four similar ones with the same rate of taper are Morse, Jacobs, Jarno, and Brown & Sharpe"
                  This is not the case – they all have similar rates of taper but certainly not identical ones. They are therefor not interchangeable.
                  #298696
                  sean logie
                    @seanlogie69385
                    I’ve put photos of the chuck in my albums . Duh… I forgot to measure dimensions .
                    Sean
                    #298697
                      Looks like you read it wrong Sean, should be JT not MJ.
                      JT refers to the "jacobs taper" that holds the chuck to the arbor, MT is the larger taper that fits into the machine spindle
                      Edited By JasonB on 18/05/2017 19:25:12
                      #298698
                      Phil P
                        @philp
                        Hi Sean
                        The photo in your album shows the end of a standard 3 morse taper shank which has a 3 Jacobs Taper on the other end with the drill chuck attached to it. Hence the 3MT – 3JT stamping.
                        This is a fairly common size, hope this helps.
                        Phil
                        Jsaon must type faster than me !!
                        Edited By Phil P on 18/05/2017 19:25:53
                        Edited By Phil P on 18/05/2017 19:26:26
                        #298701
                        sean logie
                          @seanlogie69385
                          Yep and I’m the biggest dork living . My tailstock is a mt2 , it’s my spindle that’s mt3 😣🤢😶. So now I’ll need to remove the arbour now and source a mt2 if that’s possible . Sorry for wasting everyone’s time with my stupidity.
                          Sean
                          #298703
                            Arc should have the arbor and they also do the wedges for removing chucks
                            Edited By JasonB on 18/05/2017 19:53:07
                            #298708
                            David Standing 1
                              @davidstanding1
                              Posted by David Standing 1 on 18/05/2017 21:19:16:
                              Posted by Lambton on 18/05/2017 19:06:54:
                              David,
                              You misread me (although I may not have made myself crystal clear), and only part quoted me (I went on to say Jarno and Brown and Sharpe tapers are not the same).
                              I know they are different tapers, I never said they are interchangeable, what I meant was similar as in they have a linear taper, not a stepped or compound taper like R8 or NTMB.
                              #298903
                              sean logie
                                @seanlogie69385
                                Posted by JasonB on 18/05/2017 19:23:14:
                                You sir …are correct wink
                                #298908
                                Anthony Knights
                                  @anthonyknights16741
                                  Daft question:- When Mr Morse or whoever designed these taper fittings, why did they not settle for a standard taper angle and just vary the size of the big and small ends, depending on the diameter required????????????????? or would that be too simple?
                                  Edited By Anthony Knights on 20/05/2017 08:37:07
                                  #298910
                                  Brian Oldford
                                    @brianoldford70365
                                    Posted by Anthony Knights on 20/05/2017 08:33:15:
                                    That would have been far too easy.
                                    #298947
                                      My guess is that they were meant to be nominally the same, and Morse's factory worked by reference to some toolroom standards or jigs. these may not have been particularly accurate as they would have been used as masters for making both plugs and sockets in the same factory. Presumably the standard was retrospectively applied to the taper already being used with the result that they were all slightly different.
                                      sean logie
                                        @seanlogie69385
                                        Just ordered a JT3 MT2 arbor from RDG tools
                                        Edited By sean logie on 20/05/2017 15:00:33
                                        #298966
                                        Clive Foster
                                          @clivefoster55965
                                          Neil's supposition follows the standard explanation that the slight variation in the taper angle for different sizes of Morse Taper is due to errors in the master gauges. Plausible but I don't buy it. I think it deliberate policy.
                                          Even in 1864, when the Morse Taper was invented, technology was well up to the task of producing accurately tapered master gauges. Albeit somewhat laboriously. Its setting the gauge plane that is difficult without accurate length measurement and adjustable standards. From a production viewpoint multiple tapers are a pain as needing separate masters and setting gear for each size. One size fits all, Jarno style, needs only one master calibration reference and one set up device.
                                          The variations seem too large to be simple errors and the actual tapers per foot are extremely inconvenient dimensions. This suggests that the variation is deliberate. A plausible reason is that it would force firms wishing to make equipment to use Morse drills to buy gauging and maybe production equipment from Morse with obvious financial benefits. Single sourcing gauging equipment would also help maintain quality standards. Taper and similar self locking drill / tool holding systems had been introduced before and failed to become widely adopted due to machine to machine variations giving inconsistent performance. No proper drawing standards, or even drawings, in those days.
                                          Another plausible reason for deliberate taper variation is to ensure that the system only works with the male taper fully inserted into the female one. Partial insertion of a too large male taper into a too small socket will not drive and is obviously wrong. Same taper throughout risked proliferation of odd sized and partial length variations. Probably accompanied by workers resorting to the BFH when things failed to behave. Still in the era of folk weighting down boiler safety valves!
                                          Edited By Clive Foster on 20/05/2017 18:46:01
                                          #298979
                                          Emgee
                                            @emgee
                                            Hi Anthony
                                            In later years the BT & ISO plus other range of arbors all have the same included angles but with different min/max diameters, so a BT30 arbor will fit into a INT30 spindle socket but the drawbar will need to be longer, BT tooling uses pull stud retention and doesn't have the parallel end.
                                            Emgee
