I’d like to underline Kwil’s caution about investigating VFD software adjustments before jumping to the conclusion that unacceptable motor noise is down to motor deficiencies.
I decided to convert my lathe/mill to VFD/3 Phase operation 2 years ago and I ended up with:
(a) 2 x VFD units — Telemecanique plus Allen Bradley,
(b) 3 x 3-Phase motors — 1 Taiwanese, 1 ‘EU’ (country N/K) and 1 Italian.
To keep it brief I’ll just say that bench testing any combination of these units resulted in the motor emitting a high-pitched penetrating whine that was (to me) intolerable for normal operation. I thought I’d bought a set of white elephants!
On investigating further (and with some help from another forum) I discovered that VFDs have a characteristic electronic operating frequency normally set at 2 or 4KHz by default. Commonly, however, certain (most?) VFD/motor combinations can excite accoustic resonances in the motor windings/laminations, leading to the high-pitched whine I mentioned earlier (these frequencies are well within the human hearing range, of course). Fortunately, though, most modern VFDs of any quality have software controls that allow you to change the unit’s operating frequency from 2/4KHz through 8/10/12/16Khz to ‘tune out’ the whine (in reality, the whine is still there but you’ve set it to a level above the human hearing threshold). For this old geezer 10KHz does the job.
On doing fresh bench testing after adjusting the operating frequencies I was happy to find that now, any combination of my VFDs/motors was relatively quiet, certainly very acceptable. All that remained was normal motor ‘hum’, some ball bearing noise and the ‘whirr’ of the VFD cooling fan, the latter being the noisiest component!
So, if you encounter this problem, don’t immediately start running around changing motors as I did! Check out the capabilities of your VFD first. Sadly, the manuals seem to be aimed at commissioning engineers, not home workers, and their terminology varies as between units. Persevere, though, and if you need help, post a query here or other ME sites.
Joe
Edited By joegib on 23/02/2011 11:35:36
