Hi Chris,
While I agree with you about no compulsion to change, you might be putting some peoples back up by the way you imply they are stick-in-the-mud, make that sand. People can use Imp units for as long as there are measuring instruments that can read in those units. I am sure that there would be some people still using cubits or whatever if you could still buy rulers at B&Q marked in those units. I don’t see the scale train people changing their name to metric any time soon.
Re your last Para, I think you are forgetting that nobody who uses a micrometer works in fractions. IMP can be in either expressed as fractions or decimal as you can with metres, 1/2metre is just a valid as 0.5metre. So your thought falls down a bit, 7.5mm does not have to be put into a fraction of an inch, as it can justifiably be put in decimal, 7.5/25.4=0.295″ not a “standard” figure I grant you but hardly mind mangling conversion. It must be remembered that All units of length are arbitrary as there are no accurately measurable natural constants for length, even in the metric system. Even when using light waves to measure something the wave length first had to be defined as a distance. There are physical constants involved for things like temperature, boiling or freezing of water etc but weight and length, no.
If the Earth were a perfect sphere you could perhaps use 1/10,000,000th of the equator to the north pole distance, but it isn’t and so even here some element of averaging and theoretical calculation is needed. As for light travelling so far in a vacuum in 1/299,792,458 of a second, hardly an easy number to use. Even a second is now a theoretical one, as the sixtieth of a sixtieth of a twenty-fourth of a day is variable by modern measurement capabilities. You can’t define a Metre except by calculation. I don’t suppose you are volunteering to walk from the equator to the north pole with a steel tape are you? Whereas three barley corns, or whatever an inch was defined by, are a physical , not a theoretical, unit that was fairly universal and on a “human understanding” scale. Yes, Yes, I know it is not up to engineering precision as it stands, but it worked OK as a starting point. Once you have set your arbitrary value for a metre then distance and weight are easy and dare I say it logical, but a metre is a hypothetical unit first and foremost, despite what some would say.
Please take the above in a the spirit it was intended ie not too seriously, just a bit of fun as a diversion from tonight’s fireworks.
Can our nice new bit of Eye Candy , sorry web editor, put a time limit on this topic so we can think of a new excuse for poking fun at each other. I do so hope she has a sense of humour or my posts might never see the light of day again, OK let me say it before you lot do, Yippee and thank heavens for small mercies.
chriStephens
PS Just had a thought, which is more honest a standard based on a few bits of vegetation or a standard based on a falsehood? That is a rhetorical question I’m not expecting or wanting to start another round of posts. Now, unless seriously provoked, I shall shut up on the subject. I feel a circular argument naturally goes nowhere, and must therefore be pointless.
