Posted by Paul Smith 37 on 01/03/2020 09:32:39:
Excuse the thread hijack, but can somebody with a ml10 Metric with a metric lead screw tell me how much slop you have in the lead screw mechanism please? ive got around .6mm as indicated on the leadscrew handle, roughly a third of a turn of slop before it does anything. Thanks In advance Pauly
Edited By Paul Smith 37 on 01/03/2020 09:33:10
That is some slop but not enough to be too worried about.
You should check that some/a lot of it is not from leadscrew endwise movement. This is adjusted on most lathes (i'm not familiar with the ML10, being an ML7 guy) by tightening up the adjusting nut in the middle of the leadscrew handwheel, and observing the gap between the shoulder or collar on the leadscrew and the right-hand leadscrew mounting bracket (next to the handwheel).
If it is not that, the slop is not much to worry about. It does not affect the performance of the lathe. Slack is taken up and stays taken up once the tool starts cutting. Just be sure to lock the carriage when facing etc.
My old M-Type, with similar 8tpi circa 3mm pitch leadscrew, had the threads in the half nuts worn down to .015" (.38mm) thick, giving about 2.6mm of slop, but still worked perfectly. In fact, I used it to machine its own new replacement halfnuts, which have worked perfectly ever since.
Check the ML10 owners manual too. It may have some adjustment of the halfnuts like the ML7 to tighten them up a bit. Others with ML10 specific knowledge will surely be able to comment on that shortly.
Edited By Hopper on 01/03/2020 10:01:16
