Made something useful at last
Home › Forums › Work In Progress and completed items › Made something useful at last
Viewing 23 posts - 1 through 23 (of 23 total)
  • #31186
    sean logie
      @seanlogie69385
      #325599
      sean logie
        @seanlogie69385
        Made myself a wee vee block and I'm planning a couple more out of the same piece of material . I also learned how important setting up a work piece up before machining . Also used a carbide end mill for the first time today (very impressive ) . I cut the square channel on the side using a 4 flute ,is this good practice or should I have used a 2/3 flute . Overall I'm happy with the end result . The Centec2 keeps on impressing ,I was taking what I thought were big cuts for this small mill ,the only thing stopping taking bigger cuts was the operator .
        Getting a tad impatient now to get the vertical up and running . wink 2
        Don't know why my photos are always like this on here ….
        Sean
        Edited By Neil Wyatt on 07/11/2017 15:23:54
        #325601
        Trevor Drabble 1
          @trevordrabble1
          Sean , Nice work . May I suggest you now put a nominal 3mm x 3mm slot along the full length of the bottom of the Vee in order to allow dirt and dwarf somewhere to go and also to allow any angular work to sit fully on the sides of the Vee , and so maintain an accurate register . Trevor
          #325602
          Russell Eberhardt
            @russelleberhardt48058
            Posted by sean logie on 05/11/2017 16:36:29:
            See this thread.
            Russell
            #325603
            John Haine
              @johnhaine32865
              Good stuff! When you make 2 more try machining as a pair so that they match – useful then for holding longer bars needing support at both ends.
              #325610
              sean logie
                @seanlogie69385
                Posted by Trevor Drabble on 05/11/2017 16:44:27:
                Thanks Trevor ,
                That was my next move along with a slitting saw cut along the bottom of the vee .
                Sean
                #325611
                sean logie
                  @seanlogie69385
                  Posted by John Haine on 05/11/2017 16:48:04:
                  Hi John ,
                  I've enough material to make another two which as you suggested will be a pair .
                  Sean
                  #325801
                  David George 1
                    @davidgeorge1
                    Hi Sean
                    I would also put a couple of taped holes in the base of the V block as it gives you the option to screw them to a plate or an angle plate and a taped hole in the end face so you can screw a plate to the end as an end stop for a pin or round part.
                    David
                    #325808
                    Rainbows
                      @rainbows
                      Speaking of pairs feel free to make two vertical heads and send me one
                      #325817
                      sean logie
                        @seanlogie69385
                        Rainbows no probs …. laughwink 2
                        Sean
                        #325826
                        John Reese
                          @johnreese12848
                          I believe the slot at the bottom of the V is to allow grinding withe the need for sidewheeling. Unless he intends to grind the blocks there is no advantage to the undercut.
                          #325832
                          not done it yet
                            @notdoneityet
                            Unless wanting to mount a square item to machine on one corner…
                            #325835
                              Posted by not done it yet on 07/11/2017 07:35:18:
                              I was so tempted to get all pedantic … but I shall refrain. angel
                              Yes; in practical terms that is a very fair point.
                              sean logie
                                @seanlogie69385
                                Please don’t refrain 😉
                                Sean
                                #325851
                                Martin King 2
                                  @martinking2
                                  Posted by sean logie on 07/11/2017 08:07:42:
                                  Please don't refrain 😉
                                  Sean
                                  Seconded!
                                  Pedantry from a master is so much fun! wink
                                  Martin
                                  #325873
                                    Apologies for the delayed response, Sean [and Martin], I made that post just before heading to the Hospital for my pacemaker check. … All is well, so here goes:
                                    'ndiy' has not defined any terms, nor given any tolerances; so we are obliged to make some assumptions: Mine [which I hope are considered reasonable] would be …
                                    1. A vee block has two internal faces which are flat, and arranged at 90° to each other, and are axially parallel. [More sophisticated definitions are surely possible, but I think that will suffice]
                                    2. In the context of the present discussion; 'a square item' might be assumed to be a length of material of constant section with four equal sides arranged at 90° increments.
                                    3. … Alternatively the 'square item' might only have two of its adjacent faces arranged at 90° to each other; the emphasis being on 'squareness' as a description of perpendicularity.
                                    4. My case is valid for both version (2.) and (3.)
                                    5. In the absence of any tolerances being stated, we must in the ideal case assume 'perfection'.
                                    Unfortunately, in this hypothetical 'defining case' ndiy's brief assertion falls down … because the 'square corners' would match perfectly and the groove would therefore NOT be of any advantage.
                                    ^^^ This is, of course, merely gratuious pedantry !!
                                    In the real world; ndiy's point is a good one … because the 'male' square corner may have bruises [or imperfections in its linearity] sufficient to cause it not to seat properly in the 'perfect' female vee.
                                    N.B. Many other imperfections are available … devil
                                    David Standing 1
                                      @davidstanding1
                                      Posted by Michael Gilligan on 07/11/2017 13:15:16:
                                      You didn't disappoint wink 2
                                      #325878
                                      sean logie
                                        @seanlogie69385
                                        Now that’s a reply …. I wonder if there will be any response …. dam I wish I’d stuck in more at school … you had me chuckling away to myself ….
                                        Sean
                                        #325882
                                        Jim Cahill
                                          @jimcahill55556
                                          Hello Sean,
                                          In one of his books, Geo. H. Thomas goes to some length to explain why he believes 4 flute cutters (Known as End Mills in the UK) are inclined to break as they emerge from cutting a channel.
                                          #325883
                                          sean logie
                                            @seanlogie69385
                                            Makes sense Jim , coming out the end of the cut was when the end mill groaned a bit . Should I be using a 2/3 flute for cutting channels .
                                            Sean
                                            #325888
                                            MW
                                              @mw27036
                                              Very nice, do you think you'll polish them with emery cloth when you're finished or will you leave them to a machine finish?
                                              Michael W
                                              #325909
                                                The slot in the base of the Vee will also clear any burrs on "square" stock and help it sit level, much the same as the notch on a tri-square
                                                #325919
                                                MW
                                                  @mw27036
                                                  Posted by JasonB on 07/11/2017 19:38:14:
                                                  As we know, all unmachined stock will have a corner radius that would foul the bottom of the vee. the only thing is with square stock, you would need a special kind of vee clamp screw rather than the standard screw clamp in order to hold it properly.
                                                  One other thing it's useful for is that you can stack a couple of vee blocks to get a nice 45 degree for marking out stock.
                                                  Michael W
                                                  Edited By Michael-w on 07/11/2017 21:25:23
