Hi all im after some expert advice
Ive done basic machining as part of my RnD role at work for a few years now so i have basic skills but im certainly not a machinist! I recently rescued a mk1 drummond lathe and have been busy rebuilding it! I just finished scraping the cross slide in when i realised a slight oversight… the spindle is not original (although appears very accurate) and has no spindle nose taper!!
What are my options for boring the taper? bearing in mind the lathe has been stripped so the tail stock is nowere near centered and the only chuck with the lathe is a 3 jaw which doesnt look to brilliant!
Due to the clean room nature at work i cant take the spindle in use there machines so do i have any chance of doing it in situ?
My initial thoughts were step drilling and boring it acceptable or not?
Any thoughts?
