I have a query on the opposite problem – my machinery doesn't rust in an integral garage (in Birmingham UK) which I have to share with a freezer, washing machine and tumble drier.
The metal up-and-over door means it is cold in the winter, not least because the drive leading up to it slopes down at one side for drainage. This means that, apart from all of the other gaps around the door there is a gap of over an inch there allowing cold air (and mice, or what the cats call lunch) to get in.
I have a large draught excluder coming next week to fit along the bottom of the door and intend to insulate the inside of the door with 25mm foam sheet.
My question is that while not perfect this will, I hope, help to keep the temperature of the garage up a bit, but will I then have rusting issues from the domestic appliances?
