I'm a user of motorcycle chain lube, the old PJ1 blue label went on like penetrating oil and hardened to a waxy coating. Sadly, they have changed the formula. What is the make of the Teflon type you guys use?
It has the added advantage over oil in that it quietens gear noise better.
Shafts which are lubricated with oil should not be greased, I am only recommending grease on exposed gears.
Edited By old mart on 13/06/2019 22:47:44
