lubricating lathes
lubricating lathes
Home Forums Workshop Tools and Tooling lubricating lathes
Viewing 25 posts - 1 through 25 (of 41 total)
  • #192307
    Black Cat2
      @blackcat256889
      The instructions for my new little chester conquest say use Mobil1 fully synthetic motor oil..I suppose I should!but I have iso 32 and 61 which might be less nasty for me and surely would be ok.Would it?!
      Black Cat2
        @blackcat256889
        mobil 1
        #192308
        Ajohnw
          @ajohnw51620
          You wouldn't catch me using motor oil. There is a post further down lubricating a mill. Same applies to a lathe.
          Ady1
            @ady1
            Been using 5/40 motor oil for 5 years so far
            Moved to colloidal graphite for serious work areas though
            #192315
            Black Cat2
              @blackcat256889
              And now for the oil results
              motor oil 1
              iso32 1
              Graphite no score penalty
              Chester also reccomend white lithium on the bearings..well I not using that ..
              the milling machine article has it!
              #192318
                Posted by Black Cat2 on 04/06/2015 07:23:08:
                Why are you so dogmatically against white lithium grease?
                … I'm genuinely interested to know.
                Black Cat2
                  @blackcat256889
                  Is it not highly carcinogenic?
                  #192322
                    Posted by Black Cat2 on 04/06/2015 07:51:13:
                    I've only read the abstract, but this would suggest that it is not.
                    P.S. … Some useful notes on its 'engineering' properties, here.
                    P.P.S.  Here is the MSDS for the product that I use.
                    Edited By Michael Gilligan on 04/06/2015 08:18:09
                    Edited By Michael Gilligan on 04/06/2015 08:25:38
                    #192323
                    Black Cat2
                      @blackcat256889
                      Sorry I ve been listening to wrong type of expert-no one on here!
                      #192324
                      Nigel McBurney 1
                        @nigelmcburney1
                        I have used Castrol gtx for 40 years no problem,gtx now has synthetic additive and have not tried that,been using halfords 10/40 for the last year no problem ,good lubrication, I had some Castrol classic straight 30 sae, tried it for lubricating the Colchester slides,slides were a lot stiffer to operate so that tin of oil is now used for the general purpose oil can only,
                        #192326
                        Bowber
                          @bowber
                          Very interesting set of articles about grease there, we always had a list in the workshop for which grease to use on which job and also which greases not to mix with each other.
                          Classic oils don't have the additives in to keep contaminants suspended in the oil, that's why old car engines were dirty inside and modern engines are clean, however I thought they had most of the other additives in so I'm surprised you found such a difference in operation, I know the slideway oil I've been using is better than the engine oil I was using.
                          Steve
                          #192330
                            Posted by Black Cat2 on 04/06/2015 08:31:29:
                            As the great Lou Reed wrote:
                            Don't believe half of what you see and none of what you hear.
                            [O.K. his grammar is 'New York'; but the message is good]
                            Capstan Speaking
                              @capstanspeaking95294
                              Clean engine oil is not ideal but if it was highly hazardous would it be on the shelf at the supermarket where children may buy it?
                              #192337
                              Keith Long
                                @keithlong89920
                                I wonder why a new machine – presumably under warranty – you'd use any lubricant other than what was specified in the user manual?
                                #192340
                                Black Cat2
                                  @blackcat256889
                                  Oh yes warranty..bother!
                                  #192348
                                  Nick_G
                                    @nick_g
                                    It is my understanding that motor oil is only carcinogenic once it has been used. Others will no doubt know more.
                                    I also 'thought' (while any lubrication is better than no lubrication) that motor oils were designed to perform properly above a certain temperature.?
                                    Nick
                                    #192349
                                    Muzzer
                                      @muzzer
                                      Posted by Capstan Speaking on 04/06/2015 11:02:20:
                                      Almost all petrochemicals are carcinogenic (petrol, diesel, engine oil, paraffin, kerosene etc), either from fractions within (like benzene, toluene etc) or the tiny residues like pyrobenzine which are extremely carcinogenic. We sell all manner of these freely in garages and shops.
                                      Don't ever be tempted to reuse used engine oil – it absorbs byproducts of combustion so that the concentration of nasties like benzopyrene build up with time.
                                      One pathway into the body for these petroleum nasties is digestion, where you end up cleaning your hands as you eat. Common cancers caused by ingestion as well as the above also include the nether regions and scrotum. Nice.
                                      Then there is alcohol which is fairly carcinogenic too and causes large numbers of cases of cancer of the mouth, throat, stomach, liver, bladder etc each year. At least we are gradually starting to ban smoking finally….
                                      Yes, my dad used to be an industrial toxicologist and I still have his library.
                                      #192351
                                      Graham Wharton
                                        @grahamwharton
                                        One thing to remember is that some modern oils with Sulphur based EP additives, like some modern gear oils will actually attack and corrode yellow metals, such as copper, brass and bronze. If you're putting them into your geared head, QC Gearbox or slapping them on your leadscrews, the yellow metal bushings and feed nuts might not like it at all.
                                        Graham
                                        #192361
                                        Capstan Speaking
                                          Posted by Muzzer on 04/06/2015 12:59:45:
                                          Daylight is carcinogenic and bananas are radioactive but a bit of common is required.
                                          #192363
                                            Posted by Michael Gilligan on 04/06/2015 08:15:24:
                                            On the other hand, if your machine keeps going wrong, it helps stop you getting depressed about it.
                                            EdH
                                              @edh
                                              I have just completed the modification to the gearbox on my WM280 as described by journeyman on his website http://journeymans-workshop.uk/lathemaint.php using the same oil Halfords Gear Oil EP 80W/90 GL-4, before doing this I read up on the oil specifications and found out that the GL rating is very important as GL-4 is safe to use on yellow metal bearings, brass, phosphor bronze, etc but GL-5 will corrode them so be careful which one you use.
                                              The back of the gearbox plate that you have to remove to install the mod was 1/8" thick spongy rust and the residue in the bottom of the gearbox was a gooey mess so stripped the whole assembly down and cleaned it but you have to put a chamfer on the holes the gear change knob shafts pass through as otherwise the sharp edge cuts the sealing o rings tops off.
                                              Resealed it with a flange sealant and all working well now with no leaks.
                                              Thanks to journeyman for the description.
                                              It's worth reading up on the different oil specs as it seems unwise to use an engine oil designed for hot environments in a cold gearbox, remember there's no engine heat to transfer through the casings and engines and gearboxes work under different conditions. Engine oil is slippery but so's hair oil and bath oil but you wouldn't use them in a gearbox – or would you?
                                              #192377
                                              frank brown
                                                @frankbrown22225
                                                Despite using Castrol GTX for 20 years without changing it in my lathe headstock (it did go black though), it is said that engine oils contain a detergent that hold particles in suspension, so they can be dumped at the next oil change. Which most of us do not do.
                                                When you look at the power density of a modern gear box, many push 100 HP + through lathe headstock sized gears and that the fluid last for 10 years + and multiple materials used in a gear box, these would seem to be a good candidate for use in lathes. Or just stick to a ISO 68 straight oil.
                                                And stick a magnet in the bottom of your head stock, it might attract iron particles.
                                                Frank
                                                #192383
                                                Ajohnw
                                                  @ajohnw51620
                                                  I fail to understand why people use engine oil for general lubrication of a lathe when they can buy iso 32 hydraulic oil instead. Personally though I find the best thing for slide ways is slide way oil. Little is needed and it hangs around for some time and doesn't absorbing moisture from the air or gum up like most automotive oils do. In fact I wish I could get the next grade up in small quantaties which is suitable for vertical surfaces. Automotive oils are designed to run hot for long periods. They also have all sorts of additives in them. It's also well know in some circles that if these oils are changed at say twice the recommended interval things might never wear out. They aren't as great as some might think. They did get well ahead of engine etc technology for a while but those days have gone.
                                                  Real gearhead lathes generally use hardened and ground gears. It's easy to see when a lathe has these or even by ear. I'm not at all sure what I would use to lubricate typical Chinese use of gears in small lathes and millers but I would like the sludge worn from the gears to settle at the bottom rather than circulate and grind the gears down further. I'm inclined to use grease on the back gears of my boxford and oil on change wheels and gearbox etc. I have been a bit naughty on change wheels I should use ISO 32 but use a GP oil.
                                                  I've not looked at Chinese lathe ball/roller bearings but suspect just as when the Koreans were the source of smaller lathes that some wont be hardened. From memory ArcEuro have some pages on changing NVG bearings. I've used molyslip grease on bearings for some time. My lathes have been relatively low speed in terms of what typical greases can handle. Of late because it's available I use a high speed one that ArcEuro sell. Believe it or not it will extend life. It's important to not add too much grease of any sort to bearings of this type.
                                                  Plain bearings – Myford etc really do need to use the right lubricant if they are to last. I'd hazard a guess that ISO 32 hydraulic oil meets the spec for these as well – a highly refined mineral oil.
                                                    Looking at the original post – it's a Chester Conquest.. Although there are no holes the headstock is not sealed to the bed, so the gears inside should be greased not oiled, same for the spindle bearings, apron gears, halfnut slides (as inaccessible for oiling). On my similar machine I use Finish Line Teflon Grease for all except the bearings which get moly-grease in modest amounts. Layshaft bearings are sealed for life units.
                                                    For everything else (leadscrew bearings, leadscrew, slides, bed, gears), I'm afraid I use a surplus of neat cutting oil, brushed on if things start to look dry, although a bit of teflon grease works wonders on nylon gears (e.g. the change gears). I can't detect any wear after 16/17 years of moderate (ab)use.
                                                    Ajohnw
                                                      @ajohnw51620
                                                      I don't think I would use my cutting oil Neil. It tends to collapse bottles it's left in and go down all on it's own. I just smear some on work at times. I cured the disappearing oil by putting in a sealed jam jar with a test tube strapped to the side. I just take a few gollops out of the bottle and drip it into the test tube. The test tube also serves to hold the brush I use.
                                                      The cutting oil came mail order from Morris Lubricants. 5lt which should last me for ever. Good but not as good as the thicker stuff that used to be used on auto's where splash got on peoples overalls and gave the testicle cancer and dermatitis elsewhere – there is a message there about using oils intended for other purposes. The stink of some automotive stuff is enough to put me off anyway..
                                                      secretI'm afraid I usually run the change wheels to the gearbox dry. I have been meaning to take the cover of the gearbox and use moly grease on the gears for about 13 odd years since I bough the lathe. I have put a touch of cycle oil on them at times – all wrong and have wondered about using chain lubricants maybe waxy types on the change wheels. Boxfords have a separate feed drive so the lead screw doesn't receive much attention or need it really as I don't screw cut all that often. I just make sure it's clean. Rags usually have some oil or the other on them.
