Spoke too soon didn't I – see two posts above.
Another of these high power LED's has failed, this time with a definite slow flash right from switch on.
Having done a small amount of reading, I am now thinking that the problem is one of heat in that the heat generated by the control electronics cannot escape fast enough. Interestingly, the same reason was given as a reason for early failure of CFL's, something we have experienced in this same light fitting and which was the reason for moving on to LED's.
Now I know some of you will now be thinking that maybe the fitting is at fault. From my reading, I suspect that it was originally designed for incandescents where the excess heat is to some extent radiated away. In any case, incandescents do not have electronic circuitry which may be damaged by excess heat, hence the excessive heat was immaterial.
Perhaps a new fitting, or maybe two, is on the cards.
Oh well, onwards & upwards.
Peter G. Shaw
