My 5" Super Claud build continues with the tender complete and the current work includes the driving wheel springs. I propose to use the approach favoured by Doug Hewson using spring steel suitably tempered.
Reference to the works drawings refers to 14 plates that scale to just over 3.6 inches across the hanger brackets. The question is how to arrive at the suitable deflection. I am a long way from weighing the engine!
It would be useful to know the anticipated axle weight of such an engine. The Martin Evans Claud is very much based on a Maid of Kent though I am following the original more closely with scale driving wheels and valves under the cylinders – a GER speciality. So my engine might be slightly heavier.
I used this approach for the tender but found that it was necessary to slot the spring plates to achieve the correct loaded deflection.
Kind regards
John B
