Just to update an old thread in case anyone re-visits it for reference purposes.
I've just picked up a nice little 3 phase 300w motor off a friend of mine, along with an inverter. I also had several spare inverters in stock, so I thought it a good time to re-form the capacitors in them and get everything tested ready for when I come to progress the next project. See this thread
The first inverter off the variac was a little Fuji, which I connected up to the motor; it ran as rough as a bears backside. The motor looked like it had previously been run off an inverter, as it was already set up for 240v.
Each phase out of the inverter measured the same voltage under load, with a multi meter, and gave a similar trace on my old single channel valve oscilloscope. (my 2 channel ex-GPO one has just expired.
I then followed all the advice in this thread, including my own, involving coil polarities, swapping phases round etc.
Still just as rough, though some combinations of phase order were slightly smoother, but the motor was getting inordinately warm.
Next job was to try a spare brand new motor that I've bought for the DW mill, which ran just as badly.
By now, the second identical inverter was ready to take off the variac; this worked perfectly with both motors, as did the following two inverters.
Further investigation required to compare the two Fujis, which measured the same under motor load, both on the scope and a meter.
I then tried with the motor disconnected completely, and found the "U" phase reading about 70v low, and the scope trace for that phase, off load but with the inverter set to run, was also different.
Seems I have a duff inverter, but one which seemed to measure OK when under load, presumably due to back EMF from the motor windings misleading me.
I did mention earlier that I wasn't a sparky didn't I ?
Bill
Edited By peak4 on 01/04/2018 10:33:10
Edited By peak4 on 01/04/2018 10:34:41
