If you use Armstrong style holders the curved boat piece and matching washer are pretty much redundant as the built in rake angle allows the tool tip height to be adjusted by sliding the tool bit in and out. Just make a thick washer and call it done. Actually make two. A thick one for normal turning and a thinner one to use on those jobs that need the tool bit pushed further out to avoid interference form the Armstrong holder. Using a flat washer has the great advantage that you can swivel the tool without loosing tip height setting.
Best way to set tip height with an Armstrong or lantern is to arrange for a suitably sized flat piece to be supported above the bed with its bottom side at centre height. Just slide the tool bit out of the Armstrong or tilt the lantern until the tip touches. There are a goodly number of ways in which a device of this ilk can be made. Mostly dependant on what materials are to hand in the bits box. Mine was fitted to a small Eclipse pot magnet and stalk. Not exactly ideal as the need to be slid on and off the bed along with the inherent tendency to collect ferrous swarf sometimes led to excessive worship language. But good enough that anything seriously better needed more work than I wanted to invest.
Personally I've always regarded the two slot block, easily made up from stock bar and plate sections, a much better way of carrying Armstrong holders than the lantern. Never could be doing with the lanterns tendency to move in 64 different directions simultaneously when the top bolt is released or the near impossibility of repeatable location. Also the tool tip necessarily has to divine its support at considerable distance which can, from a mechanical point of view, hardly be considered ideal.
One excellent, usually overlooked, detail about SouthBends is that the top slide toolholder fixing Tee slot widths are very slightly larger than standard Imperial bar sections. So effective, full length, Tee nuts can easily be made by screwing and gluing two standard sections together before fitting a suitable tapped hole in the middle for the stud. Hence slotted block type tool post and Tee nut assemblies can be made by screwing and gluing stock sections together without the need for milling facilities to carve from solid. In my SouthBend driving days I had several such assemblies which I used as a sort of poor mans QC system. Half a turn of the locking handle being ample to allow one block to be slid out and a new one slid in.
Clive.
