Laminated shim stock?
Home Forums Beginners questions Laminated shim stock?
  • #274966
    Andrew Tinsley
      @andrewtinsley63637
      I have just finished setting up the headstock of my ML7. The shims that Myford used are laminated shims. Each shim 2 thou thick.
      This is such a convenient way of using shims that I would like to source some of it for future use. Simply cut the shim to shape and peel off successive layers until the thickness is correct. Beats having to cut shims until all is correct.
      Is this material made anymore?
      Thanks,
      Andrew Tinsley
        @andrewtinsley63637
        #274967
          Short answer = Yes
          Longer answer = Google search for Laminated Shim Stock
          Nicholas Farr
            @nicholasfarr14254
            Hi Andrew, looks like these people do it **LINK**
            Regards Nick.
            Exactly as MichaelG said.
            Edited By Nicholas Farr on 01/01/2017 23:50:02
            #274969
            Andrew Tinsley
              @andrewtinsley63637
              Thanks Michael,
              I did a search and nothing came up that was relevant. I will use Google this time!
              Andrew.
              #274970
              Andrew Tinsley
                @andrewtinsley63637
                OK Google lists loads of American manufacturers and stockists and you can get the material on Ebay from the US at prices around £60 plus not inconsiderable postage!
                Anyone know of a UK stockist that would supply small quantities?
                Andrew.
                #274976
                not done it yet
                  @notdoneityet
                  Try adding 'UK' after your search criteria on 'goggle'. It will then prioritise (mostly) UK hits, hopefully.
                  #275031
                  roy entwistle
                    @royentwistle24699
                    The link that Nicholas Farr gave is in Worcester
                    Roy ( Happy new year to all )
                    #275136
                    Andrew Tinsley
                      @andrewtinsley63637
                      Hello again,
                      My post crossed with the one from Nick, so apologies for my unintended snub. I will give them a call and see if they are willing to sell small quantities. Most companies don't want to know about small quantity enquires for a model engineer. However I might strike lucky, well worth trying. Thanks for the lead, I will come back and let you know if they are willing to sell!
                      Happy New Year to all,
                      Andrew.
                      #275141
                      MalcB
                        @malcb52554
                        Boneham and Turner do Laminated shim. Think they still do both brass and steel.
                        http://www.boneham.co.uk/shop/product/shim
                        #275142
                        MalcB
                          @malcb52554
                          Oops!
                          Edited By MalcB on 02/01/2017 16:46:31
                          #275188
                          Martin Connelly
                            @martinconnelly55370
                            Pruftechnik Lamibloc, no idea of cost.
                            Martin
                            MW
                              @mw27036
                              This may be an inopportune place to post but is there anywhere you can still get Tinplate for soldering?
                              (apologies to Andrew for the highjack)
                              Michael W
                              Edited By Michael-w on 02/01/2017 19:04:20
                              #275197
                              John Hinkley
                                @johnhinkley26699
                                Michael W,
                                modelshop.co.uk
                                have it on their web site.
                                Hi-jack brought to a successful conclusion.
                                MW
                                  @mw27036
                                  Posted by John Hinkley on 02/01/2017 19:11:59:
                                  Michael W,
                                  modelshop.co.uk
                                  Thanks John, Much appreciated, let the normal discussion continue smiley
                                  Michael W
                                  #275201
                                    Posted by Michael-w on 02/01/2017 19:02:46:
                                    These guys seem to have plenty: **LINK**
                                    http://www.bellingham-steel.co.uk/
                                    Not sure if they would supply small quantities though surprise
                                    Edit: sorry, discussion closed whilst I was posting.
                                    Edited By Michael Gilligan on 02/01/2017 19:17:22
                                    #275205
                                    MW
                                      @mw27036
                                      Posted by Michael Gilligan on 02/01/2017 19:16:23:
                                      Thanks for the input, Michael, it looks like they've got more than i'll ever need! 😛
                                      Michael W
