You willbe lucky to find the original spec sheets for it. Ask Gallenkamp?
“Goggle” muffle furnace, rather than ‘kiln’.
Likely a wire wound element embedded in a ceramic refractory casing.
Single phase? What type of plug? How heavy is the cable rating?
Picture? Dimensions?
Possibly external panels may be of a hard asbestos-containing sheet material (like old ironing boards), but doubt there is any loose asbestos insulation inside.
Is ‘getting it up and running’ just mean it needs a plug fitting? Or is it currently non-operational for some other reason?
I had a gallenkamp muffle furnace. Not sure of model. It was about 4 – 4.5kW, as I recall.
