Posted by Howard Lewis on 13/09/2019 22:21:02:
Firstly Welcome!
Have not read through all the foregoing, so my comments may already have been covered.
The gears with missing teeth suggest that the machine has been misused (abused was my original word)
Lets hope that it is not to badly worn or damaged to be not worth restoring.
Don't worry about the Japanese chuck. Chucks to fit the 1 1/8 x 12 tpi thread are available from a variety of countries, certainly India and China. the important thing is not where it came from, but how well it and accurately it functions. Assuming that it is a 3 jaw if it holds work concentric within 0.005" it should not be too bad, unless it has been strained and the jaws are belmouthed. If this is the case, the solution is either to regrind, in situ, or to buy a chuck in better condition.
Replacement gears should be available from the RDG Tools who now own the Myford trade mark and supply spares. Home and Workshop Machinery of 144 Maidstone Road, Foots Cray, Sidcup, Kent, DA14 5HS U K may well have second hand gears, as well as other suppliers.
Don't waste money on buying a Myford oil gun. Scatter gun would be a better description; it oiled just about everything, including me, except the parts that I wanted oiled.
Buying a Reilang will be money well spent. They are good, and put the oil where you want it.
For oilers, take a look at the Arc EuroTrade website, for Oil Cups, (although these are Metric thread, not Imperial so may need to have adaptors made. Chicken and egg!) and Drip Feed Oilers which are 1/8 BSP.
There will be other sources to be found on the web, I am sure.
HTH
Hi howard
Im not too worried about the chuck, although its been suggested to me it might be too heavy for it and cause excessive wear on the spindle bearings.
From what I gather, the broken teeth are common to see on these as it appears many people try locking the chuck with the backgear engaged in order to remove it.
Not too worried about the backgear right now. Plenty of used ones on ebay from myford stuff.
Regarding oilers, the ones RDG and Myford sell look identical to the ones from china on ebay at a fraction of the price. Am considering getting a pair for the time being.
Is this the right Reilang oil can? Its all i can find but does not look like it has the right fitting for the oil nipples. https://www.ebay.com/c/524999975
Some of the oil nipples are damaged and will replace them, are grease nipples usable? It looks like thats all they are that myford sell.
As far as oil guns go, this seems to be more popular than myfords (swiss) one they sell, its made in germany.
Any ideas how good this type is? https://www.lathespares.co.uk/myford-oil-lubrication/oil-gun-myford-lathe-1
Other than that, im going to hopefully test everything out next week. My main concern is how worn the bed is and if any wear is observed on the spindle.
