It’s not rocket science
Home › Forums › The Tea Room › It’s not rocket science
Viewing 25 posts - 1 through 25 (of 48 total)
  • #385314
      You need to fix your space ship. What's the go-to tool?
      Grab a pair of mole grips!
      #35337
        Jon Lawes
          @jonlawes51698
          Ah, but those are SPACE mole grips. Exactly the same as normal mole grips but with a serial number, NSN and a price tag with lots of zeros…
          #385318
            As it's a NASA video would they not be Vise-gripssmile p
            #385323
              Posted by JasonB on 12/12/2018 16:38:10:
              'Gayechnyy klyuch' actually - it's a Roscomos video despite the NASA 'DOG'!
              Hopefully Google translate hasn't put rude words in!
              #385340
              ega
                @ega
                I don't know about Russian moles but Vise Grips and Mole Wrenches release in opposite ways.
                #385341
                  Is a space mole similar to a Clanger?
                  Neil, have you got a link to the video rather than just a .jpg as it is not a very clear image.
                  #385349
                    Posted by ega on 12/12/2018 17:46:14:
                    True! But a Mole wrench is superior
                      Never saw Scotty using a mole grip. I expect the Starship Enterprise was made of tinfoil too!
                      Edited By SillyOldDuffer on 12/12/2018 18:53:35
                      #385354
                      blowlamp
                        @blowlamp
                        I think they took a Crescent wrench when they went to the moon.
                        #385357
                        Barnaby Wilde
                          @barnabywilde70941
                          Do they have lots of different sized hammers ???
                          #385360
                          Mark Rand
                            @markrand96270
                            I was quite surprised at the gay abandon with which they were allowing bits of insulation, gold leaf, etc. to fly off into the void. I was under the impression that it was considered to be a bad thing to add to the orbital debris that is zooming around the world.
                            #385380
                            Farmboy
                              @farmboy
                              I seem to remember they 3D printed a spanner on the space station a while ago. Not sure if it was for a special job or just an experiment.
                              I bet those fancy gloves make working with fiddly things interesting, but at least if you drop something it just floats around. Not so good when you're working outside though.
                              #385382
                              RichardN
                                @richardn
                                Posted by JasonB on 12/12/2018 17:51:09:
                                (Around 1:25)
                                Edited By RichardN on 12/12/2018 22:34:46
                                #385383
                                  Posted by Mark Rand on 12/12/2018 19:48:13:
                                  I think it was a BBC video.
                                  Because the ISS is in a very low earth orbit apparently the debris will slow and burn up very quickly.
                                  #385386
                                  wheeltapper
                                    @wheeltapper
                                    Posted by Neil Wyatt on 12/12/2018 16:09:08:
                                    they were not mole grips, they were metal shears to cut through the aluminium meteorite shield.
                                    https://www.youtube.com/watch?v=Lm_fAsUTvgQ&t=156s
                                    Edited By wheeltapper on 12/12/2018 22:47:16
                                    Edited By wheeltapper on 12/12/2018 22:48:14
                                    #385387
                                    Simon Williams 3
                                      @simonwilliams3
                                      Used with a bit of Gilbow grease no doubt…
                                      #385389
                                      Clive Hartland
                                        @clivehartland94829
                                        What I understand is that the Soviets wanted the area of the hull where recently they found a hole which was leaking air into space.
                                        They are not sure if it is sabotage or something done on Earth during manufacture. So cutting out that hole and bringing it back to Earth.
                                        I wonder how they closed the hole they cut out?
                                        #385395
                                          Jeff Dayman
                                            @jeffdayman43397
                                            Clive - komplekt dlya remonta kuzova avtomobilya Trabant
                                            Edited By Jeff Dayman on 13/12/2018 05:13:04
                                            Edited By Jeff Dayman on 13/12/2018 05:14:13
                                            Edited By Jeff Dayman on 13/12/2018 05:15:03
                                            #385403
                                            I.M. OUTAHERE
                                              @i-m-outahere
                                              Dunno how they fixed it but it does raise an interesting question – can you weld in space ?
                                              #385404
                                              Pero
                                                @pero
                                                Gafferovsky tape?
                                                Perhaps this is finally the correct time to apply the term " Rocket surgery "
                                                #385412
                                                Ian S C
                                                  @iansc
                                                  I'd think space would be an ideal place for welding, no oxidation, no other nasties. Weld anyway,no gravity. I wonder if anyone has tried?
                                                  Ian S C
                                                  #385421
                                                  I.M. OUTAHERE
                                                    @i-m-outahere
                                                    Burning a hole in ya space suit would be a downer !
                                                    With no gas to ionize i wonder if an arc could be initiated or maintained ?
                                                    with no atmosphere to block out the suns rays you could probably use a big magnifying glass to heat up the metal and form a weld pool !
                                                    Edited By XD 351 on 13/12/2018 09:33:41
                                                    #385425
                                                    pgk pgk
                                                      @pgkpgk17461
                                                      Posted by Farmboy on 12/12/2018 22:25:51:..
                                                      Can you drop something in space? I have enough trouble finding that m3 nut when it's just in my shed and likely on the floor… searching the cubic volume of the shed ould be bad enough but with no walls.. And if desperate I'll use the vacuum cleaner. Out there you'd need something that cleans the vacuum.
                                                      As for welding inspace.. supposedly easy .. vacuum welding; just clean off the surfaces and they should stick?
