Is there a way to mask silver solder
Home Forums General Questions Is there a way to mask silver solder
  • #404166
    wendy jackson
      @wendyjackson
      hi out there is there a way to mask silver solder. I need to solder a bearing in place And to aline it I need to use a dumb axle. Is there a way to mask the axle from the solder. I don’t wish to end up with one solid lump. Thanks, michael
      wendy jackson
        @wendyjackson
        #404170
        Brian Sweeting 2
          @briansweeting2
          Try Tippex.
          #404171
          Paul Kemp
            @paulkemp46892
            Michael / (Terry?),
            Tippex works quite well on exposed surfaces. Not sure how effective it would be on a shaft / hole though. Better approach might be to make the bush with an undersized bore and then line ream it in situ.
            Paul.
            #404172
            not done it yet
              @notdoneityet
              Carbon black? Or loctite it in position instead?
              #404185
                Tippex works for me though it must be the solvent based one. Pic below shows two shafts being used to keep things in place during soldering and you cab see the white tippex on the shafts
                here two pins set into a piece of flat bar which hold the two bosses in position, all coated in tippex
                Part came off the jig no problem
                #404190
                Dave Halford
                  @davehalford22513
                  Rust can work or a nice coat of black scale on the dumb axle
                  #404201
                  Tim Stevens
                    @timstevens64731
                    The trade method used to be to rely on jeweller's rouge, just mixed with water and painted on. If Tippex is Titanium Dioxide there is not much difference, I suppose.
                    I don't think carbon-black would suit as it is readily oxidised in a flame to a gas.
                    Tim
                    #404228
                    norman royds 2
                      @normanroyds2
                      nicrobraz I have a bottle the label is very faded all I can make out green stop off type 11 wall colmonoy ltd but had quick look on inteweb and the company is still going regard norm
                      #405520
                      Martin Evans 6
                        @martinevans6
                        NIcrobraz stop offs, manufactured by Wall Colmonoy, come in three flavours – white, red and green.
                        From memory, White stop off is Titanium Oxide based, Red is Calcium Carbonate based – can't recall what is used in green stop off. I could be wrong – it was a long time ago.
                        Stop offs came as a paint-on liquid and also as wax sticks.
                        I used to be the technical sales rep for Colmonoy forty years ago; The UK factory (they are an American company with head office in Detroit) is just two miles from me in Pontardawe and they are going strong.
                        Martin.
