Posted by BOB BLACKSHAW on 28/07/2018 16:04:05:
The instruction manual for the VDF is quite involved for me but I will check this out, thanks.
Most VFDs have a complicated range of configuration options that allow them to be adapted to a wide range of motors and circumstances. The best written manuals are intimidating not least because, in the detail, they assume the reader is a specialist who knows what he's doing. A few hundred pages of terse jargon to decode, yuk.
The complexity of a VFD inside the black box can make fault-finding difficult. Not only could there be a fault with the wiring, or the motor, or the electronics, it is also possible that the VFD has been misconfigured in software. If it's been told by the user to behave badly, it will!
Programmable devices are often configured incorrectly by mistake even by experts. You find a setting in the manual on page 47 that looks to do what you want, without realising that page 183 explains other changes are necessary as well. This is assuming that the manual makes sense in the first place! Whenever the configuration is changed by the user, it's essential to double check it's right. It's also possible for configuration settings to be corrupted by power spikes, brown-outs, software bugs, or even alpha particles!
Configuration problems are so common that most devices provide a simple way of restoring the factory defaults. These are carefully thought out to cover common situations and guarantee the configuration will be in a sensible state before modifications are made.
If Bob is still seeing misbehaviour after eliminating other possibilities, I suggest resetting the VFD to Factory Defaults and starting again. Setting H03=1 should do the trick. (see Manual page 5-39) Once the VFD is back to a known state, see how the motor behaves, then ask again for advice about changing configuration settings to match a particular motor.
