Scrim,
QUOTE: I’m tempted to just try to get it working as before UNQUOTE:
Please don’t do that – what I need (and I suspect many others too) is for you to spend many hours working out a real good mod, then more hours photographing and writing it up, then get David Clark to publish it in MEW. We’ll all benefit that way! (Grin).
Seriously, on my lathe (mine is actually a “Real Bull”, not a Sieg) I did find it took me quite a time to set that up nicely at the start (after cleaning n degreasing) so that the self act engaged/disengaged positively each time. But so far that seems to be more or less OK still. But I would like a better system for that system though – as you say, it’s well down the list still!
Where I do have a much bigger problem is with lowering the self act rack on the bed casting and/or adjusting the carriage handwheel to take out the LOADS of backlash I’ve got – I’ve had some success with that but if I want a decent finish I still use the self act only (not the handwheel) ‘cos the handwheel has so much backlash n general “slop” that I just CANNOT get a decent finish using the handwheel – with the carriage adjusted decently (no “slop” to the bed) it’s pretty tight to turn the handwheel and it tends to “jerk” – PERFECT for a good finish!
So while you’re at it, do a decent mod for that too please (grin again) – and YES, I have seen a mod on one of the US fora re machining up an eccentric bust for the handwheel bearing.
Krgds
AES
