I also used to have "rusty" hands and can remember in my 30's anything steel based at both work and home that I used regularly were discoloured and dull. One of my colleagues, in his late 40's/early 50's never had a problem with his work tools: they were always bright and shiny. Didn't seem to affect the work though.
I'm now in my early 70's and everything is now clean & bright. So I appear to have outgrown my "rusty" hands. I suspect the answer is sweat!
As far as the engineering equipment is concerned, I used to use WD40 to protect the lathe. Bit smelly, and I often had to clean it before I could use it. Then, following correspondence in either ME or MEW, I bought some electric self-regulating heaters from RS. There are various wattages – mine are 10W. I fitted two to the lathe bed and stopped using WD40. No more rust or corrosion, and the lathe never has that bone-chilling numb inducing cold feel about it, even in the depths of winter. Fairly obviously they work by maintaining the lathe temperature high enough to prevent condensation. In addition, I also use a woven fabric cover – not sure what it is made from – and a sheet of plastic. the idea being to try and keep the heat local to the lathe. The plastic serves another function as well in that it protects against any water ingress – my garage roof is hardly the best despite now being in its 2nd replacement in 20 years.
The downside is that these heaters actually run at about 19W each, which is actually as per the specification, hence I have a constant electric drain of 38W from the lathe along with a further 19W from the milling machine which has one fitted. Ok, it costs money, but as far as I am concerned, it is worthwhile because it prevents rust and corrosion on expensive machinery.
Other people have used other means of heating their equipment – incandescent lamps under the bed, self-regulating heater tape etc.
Peter G. Shaw
Edited to correct spelling mistake.
Edited By Peter G. Shaw on 14/09/2016 13:03:22
