Good source of gear to make threading attachment for lathe
Home › Forums › Materials › Good source of gear to make threading attachment for lathe
  • #347669
    John Aitken
      @johnaitken84086
      I have an Emco Unimat 3 lathe that I’m trying to make a screw threading attachment for. Specifically for ever four turns the work piece does I want the lead screw to do one turn. 4 threads per mm.
      To do this I’d like a scours of high quality gears with a wide range of teeth numbers so can anyone recommend a good source?
      Thank you
      #29805
      John Aitken
        @johnaitken84086
        #347680
        Michael Cox 1
          @michaelcox1
          Try here:
          https://www.technobotsonline.com/
          I have sourced gears/ timing belt pulleys etc from this company. Fast efficient service and good prices.
          Just a satisfied customer.
          #347681
          Bazyle
            @bazyle
            Get a set of gears for a mini lathe from one of the usual lathe suppliers. That way they will have the right range and values.
            #347689
            Jim Nic
              @jimnic
              I'll be interested to see how you arrange the gears to drive your leadscrew on a Unimat 3.
              The U3 I have has no mechanical connection between headstock mandrel and leadscrew. The only drive I have seen is a mechanism which connects to the end of the leadscrew and takes it's drive via a rubber belt off the motor pulley as a means of feeding the crosslide, but that has a fixed ratio.
              Jim
              #347708
              Thor 🇳🇴
                @thor
                Posted by Jim Nic on 26/03/2018 20:30:56:
                Jim
                May be something like this or this? The Taig is a bit different from the Unimat 3 of course.
                Thor
                Edited By Thor on 27/03/2018 04:55:47
                #347724
                Mark Rand
                  @markrand96270
                  To answer Chris's original question. HPC gears are good quality and have a wide range.
                  Edited By Mark Rand on 27/03/2018 09:07:44
                  #347750
                  Cornish Jack
                    @cornishjack
                    I have 3 Unimats (don't ask!) one of which is set up solely for screw cutting with about 20 or so threading sets. It is a very good system in use and I think some sort of 'home-brew' copy would be preferable to a method relying on lead screw drive. The Unimat system does ensure exact repeatability.
                    rgds
                    Bill
                    #347769
                    John Aitken
                      @johnaitken84086
                      Posted by Mark Rand on 27/03/2018 09:07:27:
                      Thank. They seem to have a good suply of all the teeth numbers I could ever want. I'll go with them.
                      I’m not buying the original Unimat attachment because it is out of stock everywhere and it doesn’t do the threading I need. If I make my own I will have a larger selection of thread I can make, it will be cheaper and I will have gained some skill I would not otherwise of had.
                      #347821
                      Jim Nic
                        @jimnic
                        Good for you Chris. As I said, I would be interested to see how you do it (and I wasn;'t being facetious) so I hope you can enlighten us when you have completed it, perhaps by updating this thread.
                        Jim
                      Home › Forums › Materials › Topics
