Posted by Robbo on 08/08/2016 22:53:18:
The instructions for the Sealey bandsaw (model SM5.V3) recommends "annually replace gearbox oil -SAE90)
(This is the usual 6" x 4" bandsaw)
Edited By Robbo on 08/08/2016 22:54:11
i.e. a non-EP oil, which seem reasonable as the worm and wheel gearbox isn't hypoid.
Millers Oils supply such stuff for classic vehicles; I believe Castrol do as well, and I'm sure there will be others.
This is an excerpt from the Superwinch Husky manual, a winch often fitted to Landrovers etc. which contains a large bronze wormwheel.
Arctic -13°c to 15°c SAE 90 Oil
Temperate -16°c to 29°c SAE 85 / 140 Oil
Tropical 19°c to 43°c SAE 140 Oil
Note: EP (Extreme Pressure) additives can damage copper based alloys like phosphor bronze used for the worm gear and we do not recommend their use in the worm gearbox. If any doubt exists, consult your lubricant supplier’s technical department.
Edited By peak4 on 09/08/2016 12:11:00
Edited By peak4 on 09/08/2016 12:11:13
Edited By peak4 on 09/08/2016 12:12:14
