Fobco Quill-Depth stop Bumper/O Ring
Home › Forums › Materials › Fobco Quill-Depth stop Bumper/O Ring
  • #29747
    Madhatter
      @madhatter
      #315247
      Madhatter
        @madhatter
        Another probably bonkers question here, I have the Fobco in pieces and when I removed the quill the depth stop bumper-O ring (quill washer) has a split in it and I have spent quite some time searching for rubber washers- bumpers and the like to no avail, not that I am unable to find any, but nothing which shall suit. perhaps it is my Ocd, but the original is flat and I would prefer to replace it with the same if at all possible.
        With my vernier the OD is 65.83 mm and ID is 44.76 mm with a thickness of 3.8 mm, there is a slight gap between the rubber and the drill so ideally this could go up to 5 mm thickness.
        You would not think a rubber washer of the right dimensions so difficult to source so would appreciate any links anybody may have, please do enlighten me.
        Edited By Madhatter on 04/09/2017 23:47:09
        #315261
        Ian S C
          @iansc
          It is probably an Imperal size to start with, and the place I go to here in NZ has metric and imperial sizes of O-rings in both round and suqare section, this place is a specialist hydralics retailer.
          Ian S C
          #315293
          Martin Cargill
            @martincargill50290
            Don't know where you are located but we use a company called Manchester Seals for our hydraulic seals etc. They are good at matching seals, o rings etc. when we can't obtain them from the original manufacturer. Give them a call on 0161 832 7992.
            Martin
            #315562
            Madhatter
              @madhatter
              Hmmm, I received one quote today £6.50 each plus £4.00 packing + vat. I have tried calling Manchester seals to no avail, I noticed on the G images, someone had refurbished a star up and used what appears to be large cork washers, can't find any of these to suit either. If any one has any other ideas it would be appreciated.
              #315568
              David George 1
                @davidgeorge1
                I just got a piece of 3mm flat rubber sheet and using a pair of dividers scribed to circles till cut through and made my own.
                David
              Home › Forums › Materials › Topics
