Fine cuts on Brass
Fine cuts on Brass
Home Forums Manual machine tools Fine cuts on Brass
  • #75287
    Old Fart UK
      @oldfartuk
      Hi
      Finding myself unemployed for the first time in 42 years, ive bought a 7 x 12 minilathe to amuse myself with (I mean, whos going to give a 57 year old IT engineer whos had bowel cancer and a heart attack a job, dream on).
      Ive started making reproduction meccano brass parts, plus a few parts meccano never made but should have done.
      The problem I have is how to achieve a really fine polished cut. Im using HSS 8mm tool steel, ground on a fine grey grindstone, then polished nominally with a whetstone to get a fine edge. I turn these small parts with a bit only 1 mm wide (because then I can use it as a parting tool as well), and i turn with the lathe flat out – 2500 RPM
      The finish cut isnt bad, but its not as good as just polishing the unworked drawn bar. How can I get a mirror finish?
      Edited By Old Fart UK on 22/09/2011 17:22:49
      Old Fart UK
        @oldfartuk
        #75288
          What top rake and back clearance are you putting onto the tool.
          Brass works well with zero or slightly negative top rake and the minimum of back clearance.
          There is also the likelyhood that your thin tool if flexing or chattering which won’t help with the finish, better to have a good solid tool and try to rig up a rear mounted parting tool.
          J
          #75302
          Chris Trice
            @christrice43267
            You might want to try different grades of brass. Some of the softer yellow ones often give a better (more shiny) finish straight from the tool. You tend to get a longer swarf chip than the free machining brasses. The latter tend to cover you with very fine splinters of brass. HSS tooling honed with one of those very fine diamond thingies is more than sharp enough.
            #75343
            Old Fart UK
              @oldfartuk
              In using 5 degrees negative back rake on the top of the tip and 5 degrees end relief on the tool nose, and the tip is set exactly dead centre.
              ive been honing on a whetstone, ill try a diamond lap
              I dont get long swarf spirals, just a fine cloud of tiny chippings
              Edited By Old Fart UK on 23/09/2011 22:25:39
              #75369
              Springbok
                @springbok
                Firstly are you useing a chinese mini lathe. If so check the jib strips that there is no play with the revs you mention it certainly sounds like one. The next Q is what type of cutting tool are you useing.
                Sorry to hear about your problems and hope all will be well soon.
                Bob.
                #75404
                Old Fart UK
                  @oldfartuk
                  I dont know if its a chinese one – how do you tell?
                  I cant detect any play in the cross slide, the carriage is fairly stiff and tight.
                  This one is pretty close, the tailstock on mine is slightly different
                  The speed control box on mine looks like the above, but the tailstock looks like this on below
                  Edited By Old Fart UK on 25/09/2011 21:04:14
                  #75410
                  Sub Mandrel
                    @submandrel
                    If you’re parting and turning with the same tool, you won’t get the best results.
                    Old Fart UK
                      @oldfartuk
                      im turning reproduction meccano parts, so even if i were to make separate tools, there wouldnt be much difference, you still only need a very small tip.
                      Ive honed it with a whetstone, but ill try a diamond lap next.
                      #75426
                      blowlamp
                        @blowlamp
                        Neil is quite right.
                        A 1mm wide parting-off tool isn’t going to be rigid enough or be of the right geometry when used for conventional turning.
                        I don’t know why you would need a mirror finish on Meccano parts, but you won’t get it straight from the tool anyway, no matter what lathe you have.
                        To get that kind of finish, I usually use a very fine file (No 6 cut) to remove the ridged surface left by turning, followed by the careful use of a Water of Ayr stone and Brasso.
                        Martin.
                        PS. Have you got another name – I can’t bring myself to refer to you as ‘Old Fart UK’ all the time.
                        Edited By blowlamp on 26/09/2011 10:14:19
                        #75444
                        Old Fart UK
                          @oldfartuk
                          AHHHHHH so thats what this is.
                          i got a box of interesting junk at an auction, all sorts of stuff – blank tool bits, chucks, arbours, dead centres, all sorts, and this:
                          This is about 3/4″ x 3/4″ x 6″ long. Its very very fine whetstone – it must be a Water of Ayre stone.
                          Presumably you lube it with water? Wont using it on brass knacker it ?
                          Edited By Old Fart UK on 26/09/2011 20:41:27
                          #75458
                          Ian S C
                            @iansc
                            A bit of 1/4″ 6 mm HSS would be adequate for what you need, if all you turn is brass, and the funds are a bit tight, an old file can be converted into a good tool that will , if looked after retain a good shape edge.
                            I’v made a bit of Meccano, including 1″ pullies, made a little die to make thetwo discsthat when assembled back to back form the pully. Ian S C
                            #75482
                            Old Fart UK
                              @oldfartuk
                              Ah you mean this part?
                              Its usually made of three pieces, pressed together, how did you press the boss on tight ?
                              I wouldnt have thought these were worth making, theres millions in circulation still.
                              Edited By Old Fart UK on 27/09/2011 17:56:54
