Farm Boy
Farm Boy
Home Forums I/C Engines Farm Boy
Viewing 25 posts - 51 through 75 (of 105 total)
  • #662518
    Dalboy
      @dalboy
      What with making the crankshaft the next part was drilling and reaming for the main bearing, as well as making the bearings which was not so bad.
      Anyway this job was done without any problems but I did spend a little time setting up to do this task.
      All done and fitted just a little clean up now to get rid of some marks. I do need to ream the bearings again as the caps pinch it very slightly rather this than too loose.
      Dalboy
        @dalboy
        A simple job completed and that is to prepare the blanks for gear cutting, I need to do a little reading on the dividing head to cut the teeth.
        One of them is steel and the other bronze they also need to be just right for the diameter as well as the centre hole size.
        gear blanks (2)
        Started to set up for cutting the gears, but things needed doing first. Starting with an arbor for the gear cutter. Then discovered that my milling machine clamps were to large to hold the rotary table in the vertical position (It also acts like a dividing head) so two clamps were made luckily I could use the T nuts and the threaded rods.
        Gear cutter arbor
        rotary table clamps
        Finally managed to get set up as can be seen.
        And even better managed to complete the larger of the gears. Now that I have completed my first go at a gear I feel more confident to do others as and when needed
        gear cutting set up (2)
        Gears complete (1)
        Just a couple of small parts made over the last couple of days. I did waste over an hour looking for my 1/4″ collet which seemed to disappear into thin air, workshop gremlins at work to only find it right in front of my eyes sitting on the lathe why it should be there as I last used it on the milling machine.
        Anyway the two parts which enabled me to test the gears on the frame(rubbish video but you get the right idea) a bit awkward using one hand as I was steadying the camera with the other
        Cam assembly (4)
        Cam assembly (5)
        https://www.youtube.com/watch?v=Gic6VXUD6QQ
        #687711
        Dalboy
          @dalboy
          Turned the main body but left it on the main stock as there are other things that need doing to it that require the extra material to hold it.
          After the turning I made the two arms followed by cutting a couple of slots in the turned part, still need to drill two holes that is why it is still set up in the milling machine touch wood that will be tomorrows job followed by turning a couple of pins ready to silver solder the arms in the slots that will be another thing that I have never done before I am alright soft soldering.
          Arms only resting in place to show how they go
          govenor assembly started (5)govenor assembly started (6)govenor assembly started (7)govenor assembly started (9)
          #691442
          Dalboy
            @dalboy
            The governor parts pile has some more parts added to it all small parts but seem to take ages to do even if they are simple still some more to make. I have not yet soldered any parts as there are a few more that need hardening so will do the soldering and hardening all at the same time weather permitting as it is raining here.
            Govenor parts (1)
            if this is going take as long as it does to make a posting you can follow my build on the Model Engine makers forum if this site improves then I may start to repost again but until then see you on the other site
            #691474
            Steviegtr
              @steviegtr
              Looking good Dalboy. I have not done anything with mine since eraly last week. Other projects have taken over, need to get back to it.
              Steve.
              #691586
              Bo’sun
                @bosun58570
                Looking at the progress so far, I’m sure the finished engine will be fantastic.
                A few years ago, I watched Andrew Whale complete his Farm Boy engine, and was surprised at the amount of swarf (waste) that was created.
                Good luck with the finished Engine.
                #691599
                Bo’sun
                  @bosun58570
                  Oh, and not to mention the time it took and boredom.  I applaud you.
                  #714319
                  Dalboy
                    @dalboy
                    I had to remake the small fuel delivery bar as I was drilling it with a cross hole and messed it up as the bit was a #76 which is quite small. Now that is all done.
                    Some photos of the fuel mixer with the bar which is only 1/8″ diameter so that gives an idea of the cross hole size.
                    fuel mixer #2 (1)fuel mixer #2 (2)
                    The complete Fuel mixer just the elbow to do now
                    fuel mixer #2 (6)
                    #714323
                    Harry Wilkes
                      @harrywilkes58467
                      Nice work
                      H
                      #715462
                      Dalboy
                        @dalboy
                        The last part of the fuel mixer assembly is the elbow. Not having one, I thought I would have a go at making one which will give me the chance to do some silver soldering, as well as a very simple start to fabricating.
                        I started with 1/2″ brass bar and turned the ends and centre section as needed, with a piece of steel made a quick and simple mandrel which I loctited on and clamped at a 45deg angle in the mill vice and notched out before heating to cherry red and bending to form the angle. I thought this was easier than cutting it into two parts and trying to keep it lined up while I soldered it.
                        I filed the outer corner of the bend as it looked wrong being left with a sharp corner
                        The photos should help explain my method of making this.
                        elbow construction (7)elbow construction (8)elbow construction (11)elbow (1)elbow (5)elbow (10)
                        #715464
                        Harry Wilkes
                          @harrywilkes58467
                          Like the idea for the elbows
                          H
                          <script src=”moz-extension://47cb7401-7907-4033-9172-9608686fb294/js/app.js” type=”text/javascript”></script>
                          #715947
                          Ian Hewson
                            @ianhewson99641
                            Hi
                            I am making a Farm Boy, and am wondering if a round section Viton o ring would be ok for the piston, as square section rings seem hard to obtain.
                            Ian
                            #715951
                              I have made several hit and miss and other IC engines with single round Viton rings and all run OK
                              Only built one where a quad ring was specified and also found that difficult to get so ran it with a round one and it was OK, did also work with no ring as well.
                              #715977
                              Ian Hewson
                                @ianhewson99641
                                Thanks Jason, thought you might have done one, nice to have confirmation. All my models have been steam so far, with graphite rings.
                                Appreciate your help as usual!
                                Ian
                                #716002
                                Roderick Jenkins
                                  @roderickjenkins93242
                                  Dalby,  that’s lovely work.  The elbow is particularly fine – much better than the one I made which is nearly a right angle!
                                  Rod
                                  #716235
                                  Ian Hewson
                                    @ianhewson99641
                                    I found this gear dimensions chart at evolventdesign. Com, it gives the dimensions for mod and dp gear blanks if you input the number of teeth etc.
                                    It showed that I could use 0.5 mod cutters that I have on the same dia blanks and use the same tooth count and gear centres as shown on the plans.
                                    Saved me having to buy dp cutters or different tooth combinations.
                                    Ian
                                    #722024
                                    Dalboy
                                      @dalboy
                                      What with other jobs, not a lot of workshop time. But I have been able to apply some paint to the main body as well as get one of the flywheels set up for machining, more on that later when there is progress.
                                      Anyway the paint job it may not be everyone’s taste in colour. Thank you to all that gave advice on the best to use.
                                      It has got a top clear coat which is petrol resistant.
                                      Main body paint job
                                      #722062
                                      Diogenes
                                        @diogenes
                                        Looking good, Dalboy, – I think it’s a good colour and all your nice brass bits will set it off a treat as a complete model.
                                        #722219
                                        Dalboy
                                          @dalboy
                                          Thank you.
                                          I am also leaving the rest of the Ali parts as bare metal. The only other parts that will be coloured are the flywheels
                                          #734140
                                          Dalboy
                                            @dalboy
                                            Well after a short break from the Farm Boy what with looking after my wife after a week in hospital as well as doing the cooking and housework and trying to catch up with gardening, I have finally managed a couple of hours in the workshop even if it was only to make a collet for a 1/8″ broach to cut the keyways in the two flywheels. As well as a very quick tidy up and sorting out a new Arbor press which the wife treated me too.
                                            I should now be back with some progress. Photo of the press, but still need to slot the collet.
                                            DSCF3889
                                            #735125
                                            Dalboy
                                              @dalboy
                                              Back onto the Farm Boy with the beginning of turning the flywheels, these were done on a faceplate. Only one side on both of them the outer diameter is just a little over the final size so that once fully machining of the centre and the sides I will take the diameter to final size mounting it on an Arbor.
                                              Fly wheel 2Fly wheelflywheel 1
                                              #735742
                                              Dalboy
                                                @dalboy
                                                I have managed to start on the second side of the fly wheels, bringing the diameter to 6″ and cleaning the sides. I have started to bring the centre boss down to size, as can be seen in the photos. The flywheels are cast iron and certainly make a mess when turning, my hands were black just doing these few operations as it gets everywhere as you all know.
                                                flywheel part 2 (4)
                                                flywheel part 2 (3)flywheel part 2 (5)
                                                #739791
                                                Dalboy
                                                  @dalboy
                                                  I have now sorted out the centre boss and extended one side as they are a little short.
                                                  I have now completed the main turning on these, with only the tapered turning on one side of each to do, and the holes drilled for the fixing flange to attach.
                                                  I also managed to form the keyway on both, which I was nervous about as the broach is only 1/8″ wide, but it went a lot easier than I expected.
                                                  Fly wheel with keyway 2Fly wheel with keyway
                                                  #743167
                                                  Dalboy
                                                    @dalboy
                                                    If I thought I was back on track with my last post, it has only taken me since then to drill and tap 6 small holes. This was due to me going down with a severe chest infection and not fit to play with machines.
                                                    Hopefully (touch wood) I am now back on track.
                                                    Fly wheel drilled and tapped
                                                    Fly wheel drilled and tapped 1
                                                    So nearly finished the flywheels, just need to put a taper in the centre hole which will become clearer in the operation after that
                                                    #747762
                                                    Dalboy
                                                      @dalboy
                                                      What with different things getting in the way, I finally got around to a little more work on the Farm Boy engine.
                                                      The flywheels needed a taper putting in the crankshaft hole and also a tapered fixing made to match. Going by the plans, the opening in the flywheel just cut into the three screw holes, which surprised me.
                                                      I mounted the flywheels on the faceplate and dialled them in before setting the angle and turning these. Both flywheels were done before turning the matching locking fixings. This meant that the cross slide was already set and both tapers matched.
                                                      Still need to drill the fixing holes and also two threaded holes to use if they need extracting from the flywheel in the future as well as a slot.
                                                      Flywheel inserts (1)
                                                      Flywheel inserts (2)
                                                    Home Forums I/C Engines Topics
