Hi Exmoor
Jeff Dayman & JasonB have just about covered all the requirements for building up your workshop; I have a Warco WM250V-F (with power x feed) lathe & the WM 16 mill, both bought at last years Harrogate exhibition. I had a very good look at Chesters, Amadeal, Arceuro to compare prices & 'package deal' offers & Warcos came up with the best deal (stands included) so I parted with my cash.
As far as support goes I can only give you my experience..Warco initially sent me the wrong machine, a standard 250 as opposed to the V-F, a telephone call to them soon remedied the mistake & I had my V-F within the week ,delivery costs taken care of, on checking the second machine I found that the saddle was severely binding along the bed at three points, poor casting manufacture & finish, the stand was of a quality that a first year fabrication apprentice could have done better,again a phone call, plus e-mail with photos had another machine & stand on its way, all this with profuse apologies & delivery costs taken care of. This machine has proven satisfactory to date & apart from a clean up of the travel grease etc I've had it working ..'straight out of the box' .. & apart from blowing a fuse ..my fault, I was testing how much a cut I could take off.. it has handled what I've thrown at it (not literally !!). I can concur with Jeffs comment on checking the drive belt though, it is only 1/4 " wide..so bought another .. 'just in case', & not cheap, any how ref back to the support point, Warco were very apologetic & immediately acted on the issues mentioned so I can't complain. I did mention during the phone calls that a better quality control & inspection system at point of manufacture would have prevented a lot of issues & I was assured that this has been taken on board.
The mill was ok from day one, again 'straight out of the box' & a general clean up soon had it running, a bit of a rattle coming from the head but I put that down to the plastic intermediate gears (seems to be a common denominator with most of these Chinese machines). I did check the bearings via the old mechanics trick of listening with a screwdriver as a stethoscope on both top & bottom bearing housings & did not detect any overloud rumbles or clicks so have left it at that. It also has coped with what I have asked it to do, including intermittant cutting on cast iron (bloody awful stuff to clean up!) & so far is coping with DOC of up to 1mm with a face mill & more with a HSS 4 flute end mill on cutting MS T bolt..so I can't complain. All in all both machines are doing what they are given quite satisfactorily,& accurately, & as we all know 'you don't get a Rolls for mini prices'
As far as tooling goes I have over the past I have bought a 4" tilting rot' table, a set of ER 25 collets & MT2 & 3 holders, various milling cutters,drills, mini chucks, keyless chucks,etc,etc, from the usual suppliers.. Arc Euro,Chronos, CTC (Hong Kong) ..usual discalimers, & flea bay, did actually manage to get a carbide 12mm ripping cutter for .50 pence, & 8 & 10 mm carbide end mills for a £ 1 ea. on fleabay..mind you postage was £3.40ea. from China..hmm! wonder who came out the winner there ?
So Exmoor, there you have my experience of setting up shop; NB; set yourself a budget, decide what you want to do, get the largest you can afford & have space for, & bear in mind the old adage ..'what you spend on machines you'll spend as much if not more on tooling ' in one form or another. I have a couple of photos of my machines in my album should you /anyone wish to have a look
Cheers & happy hunting.
George.
