Thanks for the information about the steels.
How does this sound:
I will check for marine U-bolts again, I have already checked but it is to go around the seat stays of my mountain bike to fit some stabilisers, they need to be a particular size to replace the ones that broke before I applied hardly any torque. The original set were very weak.
The U-bolts are 6mm diameter.
I was going to use EN24 or EN26 and get them Parco-luberized so they are coated black, they will be rubber coated black over the contact section.
I may try making them from EN24, with no heat treatment to minimise cost.
I can see if I can tighten this up without it breaking, using off the shelf nyloc nuts,
Or can I make this from EN24T. What is this like to bend? The U-bolts are about 35mm wide and 75mm high.
