Electronic mouse trap
Home Forums General Questions Electronic mouse trap
Viewing 25 posts - 1 through 25 (of 45 total)
  • #276630
    JimmieS
      @jimmies
      Hi Folks
      Our daughter lives in an old tenement building and has mouse problems for over a year with little success at catching or killing the beasties. The 'mouse man' (professional pest expert) said that rodents are wise to almost all traditional design and form of traps, sticky sheets and poison as she has found out. I am thinking of a diy trap design on which the bait is hung from a hook positioned above a copper strip, the mouse acting as the switch by completing a circuit when it grabs the bait.
      Any ideas about the requirements would be appreciated.
      JimmieS
        @jimmies
        #276632
        herbert punter
          @herbertpunter99795
          Get yourself a tom cat, job done…
          #276634
          Carl Wilson 4
            @carlwilson4
            Don’t feed said cat though.
            #276637
            David Standing 1
              @davidstanding1
              Rentokil Advanced mouse trap, and a pea sized ball of peanut butter, works for me, I catch endless mice with this.
              #276638
              Brian Oldford
                @brianoldford70365
                Is the intention to electrocute the mouse or trigger some solenoid or motor operated way of dispatching said mouse?
                #276640
                Speedy Builder5
                  @speedybuilder5
                  All you need is a shaving mirror and a saucer of whisky, Oh and a keen cat. The mouse drinks the whisky, then sees himself in the mirror as a huge mouse, and picks a fight with the nearest cat. Even the cat is happy having eaten a really tasty mouse.
                  On a slightly different tack, my friend installed a couple of ultrasonic mouse deterrents and has never had a problem since they were installed. This sort of thing:-
                  BobH
                  #276645
                  Emgee
                    @emgee
                    Spend a few minutes making this one. **LINK**
                    Emgee
                    #276646
                      I've found that the simple humane traps work more reliably than 'little nipper' although I have a large Longworth type trap used for everything from mice to gerbil recapture.
                      Rats, I used to use an extra-large spring trap or my air rifle, but for various reasons they are mostly absent now (cats help).
                      Hacksaw
                        @hacksaw
                        Posted by Emgee on 08/01/2017 21:21:37:
                        Emgee
                        Ha Ha Ha that's ace !
                        #276651
                        roy entwistle
                          @royentwistle24699
                          JimmieS Remind her to switch off before removing corpses
                          #276654
                          Harry Wilkes
                            @harrywilkes58467
                            Emgee
                            Like it thumbs up
                            #276658
                            duncan webster 1
                              @duncanwebster1
                              I use an old fashioned trap, but put half a rolo on instead of cheese, they have to really tug at the sticky toffee, which reliably sets it off.
                              If you want to make something clever then a platform which gets depressed by the mass of the mouse triggering a microswitch would be easy, or even better an infra red light beam across a tunnel. You could have a revolving drum (think big bore revolver) and trap more than one
                              #276664
                              Frances IoM
                                @francesiom58905
                                a small piece of high quality chocolate (ie one with strong chocolate aroma 75% cocoa + above) melted onto the old fashioned wooden based little nipper worked well for me – just be prepared to deal with the dead (the choc + trap can be usually recycled as the mouse should be hit before getting the choc) and check very regularly as mice come in families – place the traps along edge of room or internal runs in build in cupboards etc
                                one key is to place to force mouse accessing chocolate head on
                                #276665
                                JA
                                  @ja
                                  Emgee
                                  I like the trained mouse.
                                  I have found chocolate works a treat as a bait. However your mice may be too street wise for simple country things like that.
                                  I think a cat is the real answer.
                                  JA
                                  #276666
                                  duncan webster 1
                                    @duncanwebster1
                                    Posted by JA on 08/01/2017 22:37:01:
                                    Emgee
                                    JA
                                    But then as the old children's song says then you'll need a dog to get rid of the cat and so on add nauseam
                                    #276668
                                    David Standing 1
                                      @davidstanding1
                                      Posted by Neil Wyatt on 08/01/2017 21:28:18:
                                      I also have a rat issue, Fenn Mk 6 traps and likewise an air rifle are effective!
                                      #276669
                                      Emgee
                                        @emgee
                                        JA
                                        I think a cat is a great idea but no longer have one.
                                        The bottle is baited with peanut cream/paste just below the neck.
                                        Emgee
                                        #276670
                                        John Haine
                                          @johnhaine32865
                                          You can buy quite cheaply ultrasonic mouse repellers, we got from Aldi last year, plugged it in and the mice moved out.
                                          And remember, the early bird catches the worm, but the second mouse eats the cheese.
                                          #276672
                                          Hacksaw
                                            @hacksaw
                                            Last year i switched on my ancient Ironworker ( like a Kingsland ) and there was an awful scream and thud thud thud ..Scared the crap out of me ! Switched it off as it had stalled the flywheel and the belt was slipping …Gave it a few minutes wondering what the hell it was still thumping in the machine …..Shaking i opened the side , and there's 2 large cast gears , covered in grease …and this rat has gone head first through the pinion and the gear jamming it up ..It must have been eating grease when i started it .
                                            #276673
                                            Clive Hartland
                                              @clivehartland94829
                                              This may seem a strange one, I had mice in my workshop in the Barracks in Dortmund. I got an empty oil drum about 2 foot tall and 15 inches dia. I placed it at the end of the bench and at night before I left I placed a ruler over the edge of the desk and put a small bit of cake on the end of the ruler. In the morning I had on average 2 mice in the bin plus the ruler, this went on for a while until I did not catch any more for a week or two.
                                              Disposal was by toilet flushing! At Leica the girls would leave their choccy snacks in their desk drawers and sure enough the mice would find them. I set out a half dozen humane traps and baited with choccy or apple pieces. Sure enough I caught the mice and the easy way was to flush them.
                                              #276676
                                              Hacksaw
                                                @hacksaw
                                                Good job you put " desk"…there..
                                                #276681
                                                norman valentine
                                                  @normanvalentine78682
                                                  I had rats in my house. I bought a large bag of poison pellets. Set a few where I had seen a rat and put the bag away in a cupboard. Next morning I found that the rat had chewed its way into the bag and stolen most of the poison. I didn't see any more of them after that.
                                                  #276686
                                                  John Olsen
                                                    @johnolsen79199
                                                    Cheese is certainly not the ideal bait. One thing to try is a bit of bacon rind. It is worth giving it a little toasting over a match after putting it on the trap to get the human smell off it.
                                                      Posted by duncan webster on 08/01/2017 21:53:31:
                                                      I know what you're thinking: "Did he catch six mice or only five?" Well, to tell you the truth, in all this excitement, I've kinda lost track myself. But being this is a .44 Magnum, the most powerful handgun in the world, and would blow your head clean off, you've got to ask yourself one question: 'Do I feel lucky?' Well, do ya, Mousie?
