I'm sure you could use a conventional solid carbide bit, but they are rather expensive.
How about a solid carbide spotting drill which often appear on ebay at reasonable prices?
I've actually got an (out of commission) Manchester Rapidor Minor, which takes 9" blades.
I use the carbide tipped drill bits, often obtainable at model engineering shows, from the chap who demonstrates drilling files etc.
They worked fine, provided you clamp the blade tightly to a piece of sacrificial steel to save any problems when it breaks through.
I've also used conventional masonry bits, touched up to be sharp on a diamond wheel.
I found high speed, no lube, and plenty of pressure worked best, but make the sacrificial steel a reasonable size to act as a heat sink, to save melting the brazing.
Bill
