Does a 1600rpm bantam have a single v belt?
Home Forums Manual machine tools Does a 1600rpm bantam have a single v belt?
  • #405055
    Mark Davison 1
      @markdavison1
      Does anyone know if the 2 speed / 1600 rpm Colchester Bantam came with a single or double V belt. I'm about to fit a 2 hp 230v 3 phase motor/VFD in place of my single phase 1hp motor (800rpm machine with a single belt). I would have gone for 3hp but I got an old but unused 2hp cast iron Brook Crompton for a really good price).
      Manual seems to suggest it is only a single pulley.
      Mark Davison 1
        @markdavison1
        #405058
        Emgee
          @emgee
          Single belt on mine, a 1996 model.
          Emgee
          #405071
          Emgee
            @emgee
            Correction, should be 1966 model, GB World Cup winning year.
            Emgee
            #405074
            Falco
              @falco
              Mine has a single belt also. 1967 model if memory serves me right. J
              ohn
              #405082
              Pete Rimmer
                @peterimmer30576
                I put a 3hp motor on a Bantam with a single belt and ran it up to 1600rpm on the VFD no problem at all.
                #405094
                Mark Davison 1
                  @markdavison1
                  Thanks everyone
                  #405095
                  Niels Abildgaard
                    @nielsabildgaard33719
                    I found two old motors and they smellt very bad being VFD-ed.
                    I then bought a new and total happines.
                    How old is the motor?
                    #405096
                    Mark Davison 1
                      @markdavison1
                      Not sure, don't recall seeing a date on the data plate. They (i bought two) are 90 frame as opposed to imperial, with moulded plastic fans and fan shrouds. Dual voltage as standard. Saw it run on a 400v rotary converter before I bought it and all seemed well. Nothing ventured nothing gained. Worst case I have to cough up for a new one, which is what i had previously intended to do anyway.
                      #405119
                      Clive Foster
                        @clivefoster55965
                        Mark
                        I think its safe to say that any dual voltage Brook Crompton motor modern enough to be a 90 or other post imperial frame size will be perfectly happy running on an inverter. Especially if you stick to the old conservative ± 1/3 rd of data plate speed range. No cooling fan issues, no significant torque loss at lower speed issues (in home shop use anyway) and no odd internal electrical / magnetic interactions to upset things. Although the latter is more likely with a budget "count the turns near enough" re-wind. These things were designed to run on nice 50 or 60 hz sine waves using, by modern standards, pretty basic formulae so no sense in pushing the envelope.
                        In your position I'd seriously consider altering the pulley sizes to lower the gearing a little and make better use of the high speed end of the inverter drive range. Take a good look at the speeds you tend to use and try to set the gearing to minimise gear changing.
                        (Not an inverter I know but the high speed range of Reeves varispeed drive on my S&B 1024 often drives me nuts because bottom direct drive speed is 330 rpm or so when 200 or thereabouts would avoid a lot of switching in and out of back gear. I'd never miss the difference between 2400 and 2200 at the top.)
                        Edited By Clive Foster on 15/04/2019 11:09:09
                        Edited By Clive Foster on 15/04/2019 11:09:32
                        Edited By Clive Foster on 15/04/2019 11:09:55
                        #405186
                        Mark Davison 1
                          @markdavison1
                          I'm primarily interested in getting access to speeds above 800rpm which is the max with the current single phase motor. The low speed is fine. At the moment I've order exactly the same size pulley, but may also order a slightly larger one as (I think ) you're suggesting
