boring on any machine tool , you must remember that if the work is held in a chuck 3 or 4 jaw, the chuck jaws should not be tightened too much, just lightly or else after you bore and remove the job, you will find the bore slightly bigger on the places where your chuck jaws were. This is due to spring back of the item after removal of clamping forces.
To correct you can hone the bore
If you bore on a mill with swivel head, unless the vertical spindle down feed is not used but table up feed is used, you can get an accurate bore. If you use the quill feed make sure that the quill is absolutely vertical to the table in Z axis by using a dial gauge to true the quill on both horizontal and vertical axis. If not the bore will be slanting to the error of the quill.
The boring tool should preferably made of a rigid carbon steel rod hardened and tempered to prevent vibrations. the tool cutting edge to have a very minute radius on the tip, approach angle of about 80 degree. To hone the hole what you can do is turn out a wooden shaft to about 1mm smaller than the bore, split the wooden shaft about 25 mm depth in the longitudinal axis, slip in a short strip of SiC abrasive grit 200 to 400 paper , roll it round the wooden pole and you got a honing tool. Use kerosene as honing fluid. Flush out regularly to get good finish.
Vasantha from Sri Lanka
