Before fitting the pipes found in the box, do flush them through to clean them. The holes in the injector nozzles vary in diameter between 0.013 inch to 0.021 inch, so can be blocked VERY easily, and that could mean a new Nozzle, which will be expensive. (If you can get genuine ones for an older engine)
And check that the pipes are all the same bore as the originals
The Injector pipes used on older Perkins engines (pre Emissions controls) will be Bundy (Which is actually thin steel sheet wrapped into a pipe form.) The ends will be formed, not fitted olives.
Those pipes have to withstand pressures of upto 600 bar. So don't force the pipes into place, and do use the proper clips, in the original position, to hold them. Ignore this, and you could have pipes break, usually when least convenient or safe!
Only replace high pressure pipes with ones of the same length and bore. (At Perkins, we used three different bores, depending on the output and application). Some may have the bore printed on them, under the paint
Fuel Injection pumps, especially rotary ones, are VERY sensitive to pipe length and bore.
As an ex CAV, and Perkins, Development Engineer, believe me that a vast amount of time and effort has been devoted to matching the Injector pump, high pressure pipes and Injectors to achieve the required performance.
And this includes the spec for the Governor, The DPA injection pump has about 30 different governor springs available, which can be fitted in nine different ways, to control a variety of metering valves. So the possible combinations of pump specs runs into hundreds, if not thousands.
Use any part, not intended for that particular combination and the starting / performance / fuel consumption WILL be adversely affected. You could even damage the engine in the short, or longer, term
If you need new H P pipes, buy the proper ones. The above will explain why they are expensive.
Beware of "spurious" Fuel Injection spares. I have checked out some of the "Afterrmarket" parts, and a lot is rubbish. Can you imagine a universal "one suits all four cylinder engines" pump? These have been offered, .and the chances of getting one that exactly suits the engine are pretty remote.
