Cutting circular slots in mild steel
Home Forums Beginners questions Cutting circular slots in mild steel
  • #153039
    Ed Duffner
      @edduffner79357
      Hi guys,
      Title should have read Circular blush
      I'm now making two off MS plates to house the bearings for my lathe headstock. The only method I have to achieve this is to clamp a plate to my rotary table and use and end mill to progress down to 16mm and almost out to full diameter. I then creep outward on the final interference diameter for the bearing outer. This creates a circular slot because the centre section is the only way I can bolt the plate to the RT.
      The plates are 20mm thick and I'm cutting down to a shoulder 16mm deep for the bearing to pull in against.
      I've done one plate already and my 8mm, 4 flute end mill is getting rather blunt. At the moment I don't have a cutter-grinder.
      Being a relative beginner in machining I was wondering would this be better done using a 2 flute slot drill or roughing mill and finish with a 4 flute end mill?
      Cheers,
      Ed.
      Edited By Ed Duffner on 20/05/2014 18:35:05
      Ed Duffner
        @edduffner79357
        Which cutter(s) to use?
        #153040
        Thor 🇳🇴
          @thor
          Hi Ed,
          if your initial cut is a circular slot I would use a slot drill (2 flute). If making the slot wider an end mill might be better. Your cutters going blunt when milling steel is something I have experienced too, there can be several causes. Either grind/sharpern the milling cutters or get new ones.
          Thor
          #153042
          Ed Duffner
            @edduffner79357
            Thanks Thor, yeah I'm thinking about getting another cutter hence the question about which might be best for slot work. If it was a straight slot I'd probably go for a 2 flute slot drill, but I was unsure if a circular slot required a different approach.
            #153045
              How big is the plate? can you do it in the lathe its basically a similar method to Trepanning where we have had a couple of recent threads.
              Ignor this if the lathe is out of action until the plates are made.
              Edited By JasonB on 20/05/2014 19:45:05
              #153061
              Nobby
                @nobby
                Hi Ed and guys
                I would use a slot drill for rough slotting then finish using an end mill . if the spindle is zeroed to the centre of the rotary table and dials set. Move Y axis to radius required less 1/2 cutter (R minus ) less say about 10 thou . run round dont climb mill . as it may snatch when you are milling round the slot . check size for fit may be 20 thou small repeat to finish . Leave approx the same on the bottom . you can then remove the centre metal not required clamping direct on milling table . the CNC guys would have a canned cycle for this job What mill are you using ?
                Nobby
                #153078
                Ed Duffner
                  @edduffner79357
                  Thank you Jason and Nobby, the lathe is out of action, this is part of it I'm rebuilding. I have two 125 x 100 x 20mm plates to make the faces, it'll be a bit like the Sieg headstock casting with pressed in taper-roller bearings but only the ends where the bearings are. The plates will be bolted to a base plate on the lathe.
                  Nobby, you have described what I'm trying to achieve very well. I was a bit coy on the first plate and left about 1.5mm in from the edge as I didn't want to get too close. I keep forgetting that 1.5mm is actually a very large distance in engineering terms smiley I am doing something similar to CNC where they spiral the cut down about 0.2mm for each rotation, but manually in the first 15mm or so of each pass.
                  I will get a 2 flute slot drill to finish this job off. I am using the Warco WM-16 milling machine.
                  Here's the idea. The left plate is as clamped in the mill and the finished item on the right.
                  Thanks again,
                  Ed.
                  #153081
                  Ed Duffner
                    @edduffner79357
                    I managed to find an imperial slot drill in my Dad's stash of tooling so can continue today.
                    Thank you to whoever changed the title spelling, JasonB ?
                    #153095
                    John Stevenson 1
                      @johnstevenson1
                      Perhaps a silly question but why can't you rough out and use a boring head to get the bearing diameters ?
                      #153124
                      Ed Duffner
                        @edduffner79357
                        Hi John, no boring bar, not much money at the moment. I want to eventually make a boring bar as per Harold Hall's design in the Milling Book. …but I need a lathe to do it.
