Posted by Ajohnw on 06/01/2017 17:21:44:
You need to know what is tripping out. I think that the rcd is generally right next to the big on off switch. The others will be current trips.
A 1kw motor may take a lot of current when it starts ac or universal dc which is what you have.
There can be several reason for the rcd to trip especially on brushed motors. Effectively they are detecting a miss match between the current going to the motor compared with what's coming back.
The insulation in the motor may be past it's best.
It might be full of dust including dust from the brushes. Sometimes this can be cured by stripping it and cleaning it very thoroughly.
These types of motors sometimes have suppressor capacitors built in. They can cause this sort of problem. So replace both with new ones or remove them. I didn't mention removing them.
I believe your rcd should be a 30ma type. In the early days much much lower values were often fitted.They caused all sorts of problems with lots of things. They are pretty simple things really. Maybe they can go wrong. Probably will if tripped frequently. They usually plug into the consumer unit so can be changed. I think some consumer units use a combined master switch and rcd. Those are likely to plug in as one unit as well. So will the current trips. None of this sort of stuff is intended to do it's thing very often.
Umm… John, some of what you say is perhaps confusing. so…….
actually, often in a modern consumer unit there are two RCDs. Often one at each end (or one at the end and one in the middle). On mine I only have one but it is the half way along the row
For the record, an RCD is generally easy to identify by the fact it has a test button and is double width. An RCBO has a test button but is normally single width.
I don't think I have ever seen an RCD with less that 30mA rating in a domestic consumer unit. Perhaps you are thinking of Voltage Operated Earth Leakage Circuit Breakers? They were a menace and I think the recommendation is to change them wherever they are found.
They do go wrong and can be damaged if they trip when there is too high a current flow. They should be tested every 6 months using the test button and every 5 years using a proper tester. And replaced if they are known to have taken a full fault current. Not that either generally happens…..
Sometimes, but it is not common in the UK. I think (although I will stand corrected…) that RCDs do not meet the BS standard required for a main isolator switch. It is more common in garage consumer units where the RCD is not the main isolator (that is in the main board in the house).
I am assuming your reference to plug in units refers to the old plug ins that replace cartridge or wired fuses in the likes of MEMs or Wylex boards. I am not aware of any modern boards that use plug in breakers, assuming you don't count the crabtree starbreaker boards that have a plug in busbar connector.
hth. Toby
