Compulsive buy… now I need a “new” lathe.
Home › Forums › Related Hobbies including Vehicle Restoration › Compulsive buy… now I need a “new” lathe.
  • #839726
    dixiethedog
      @dixiethedog
      I always seem to have motorbike projects on the go. In my head I have plans and designs for bikes way down the line that I don’t even own yet. If I see parts that are interesting and handy for the future, if I have spare cash, I will buy them.
      The other day I spotted a (I think) cool split rim wheel for hardly any money, so I bought it.
      641583401_953143237042482_5965440659834262435_n
      #839727
      dixiethedog
        @dixiethedog
        Now I am stuck, as one thing that I am not keen on is mismatched wheels on motorbikes.
        The gent I bought the wheel from (online) has told me that he has a billet of alloy and two rims that he had planned on having machined to make a matching rear wheel (6.5 X17).
        I am not that confident, defo not an expert, on machining, but I figure if I can get my milling machine up and running I should be able to machine the centre section (slowly). Alternatively send it out to be done.
        Before Christmas I sold my trusty good old Boxford CUD as I decided I needed a lathe that can be bench mounted that would free up a bit of floor space. The plan being to stick a compressor under the bench to safe space elsewhere. To make wheel hubs I do need to get myself sorted with a new lathe. The main choice was a Warco model. I like the look of the new one with the ELS system on it. But since joing here I received a smashing private message from Luke at Amadeal, and their lathes look great too. To make a pair of wheel hubs I need a lathe!
        #839750
        Nigel Graham 2
          @nigelgraham2
          If your main metalworking is large parts for motorcyles, surely you’d need larger machine-tools than those; but if you are not confident on your skills will you be confident riding on your results?
          #839764
            Bench mounted 250 would have 10″ swing, Bigger spindle bore and longer bed, higher spindle speed than a Boxford so capable of larger work than the OP’s original Boxford.
            #839773
            dixiethedog
              @dixiethedog
              Hi Nigel, when I mention confident skills it is more of a “will I take a thou too much off this piece or that”. Or as I am not particularly experienced (as in properly trained) the shift in confidence could be “am I doing this in the best manner” (would somebody with more experience do it differently?).
              I would not put my life or other peoples life’s at risk though!! 😊 I potentially have 2-3 home machinists in place to do the job for me.
              One of which is my old mate Robbie (who I have not yet spoken too about this). He builds custom choppers and stuff that wins best engineering awards when he enters his bikes into shows. He also is able to widen stock motorbike wheels (from 6 to 12 inches!). He has the gear and knows how to use it. Here is one of about a hundred bikes that he has built from scratch. He makes everything apart from the engine and tyres. LOL.
              943334_524864630884099_1154633584_n
              Another lovely bloke is involved with a YouTube channel, but I don’t want to name names even though this has been discussed with him and it appears that the green light for go is on. I would love to have this man do the work and maybe even see a YT video of it being done.
              Another is a mate who owns a motorcycle engineering restoration business. I could probably go and use his lathe and then his (or my own) milling machine with his supervisiona nd advice when needed.
              But your sentiment is 100% correct. I will not do anything that could hurt or even kill anybody. Doing a bracket here or a spacer there will not harm anybody, but doing a wheel wrong would be a distaster.
              #839774
              martin haysom
                @martinhaysom48469
                could the compressor go outside. mines in a shed switched from in the workshop
                #840061
                dixiethedog
                  @dixiethedog
                  Outside is not an option for me, sadly.
                  But the idea of fitting inside a box (as if outside) and then soundproofing it could work.
