Combined FWD/REV switch plus potentiometer for mill power feed.
Home Forums Beginners questions Combined FWD/REV switch plus potentiometer for mill power feed.
Viewing 3 posts - 26 through 28 (of 28 total)
  • #287830
    John Rudd
      @johnrudd16576
      Ed, methinks you are on the right track with the physical stuff, the fast traverse can be achieved electronically with a normally open switch ….to which you already eluded…need help,with it? Shout up.
      Ed Duffner
        @edduffner79357
        Thank you John, very much appreciated.
        Ed.
        #287846
        Clive Foster
          @clivefoster55965
          Ed
          Considered a number of layouts in my efforts and would not use a yoke to mount the potentiometer. Simply screw through the panel into a relatively large diameter bushing and run the direction selector lever on that. Large bush isolates the pot knob from the lever and gives you somewhere to put an O ring for drag if need be.
          Switches go outside the potentiometer so its all pretty flat. Shallowest form is to lay the micro switches flat on the front with the switch operating operating / detent notches directly on the outside of the lever boss instead of using a separate cam. Put a slot at the bottom of the cover to accommodate the direction lever swing, ± 20° should be more than adequate. Big advantage of that layout is it gives a nice surface for speed calibration dial. Direction lever and switch pack should come out rather under half inch deep depending on how thick you make the cover.
          Clive.
