Colchester Chipmaster Tailstock cleaning
Home Forums Manual machine tools Colchester Chipmaster Tailstock cleaning
  • #375101
    JB
      @jb
      Hi
      I've recently acquired a Colchester Chipmaster, the serial number I've found dates it to 1980. I've also got hold a manual that shows 2 tailstock variants, including the later version which matches mine (I've not found a serial on the tailstock, so can't be sure it's the original one).
      The lathe came covered in years of swarf, soot and hardened grease so I'm giving it a good clean.
      I'm starting on the tailstock and have got most of it dismantled, but I can't get the barrel out. The combination of the barrel, the clamping pad and the barrel clamp level seem to all interlock and stop any one item being removed.
      Has anyone had a similar issue and overcome this problem?
      Thanks in advance.
      JB
        @jb
        #375130
        Emgee
          @emgee
          Hi JB
          If the tailstock is functioning correctly why do you need to dismantle ?
          If it aint broke don't fix it.
          Emgee
          #375135
          Bazyle
            @bazyle
            There is probably a burr raised on the clamp pad by the lever. Just a guess.
            #375350
            Brian Wood
              @brianwood45127
              JB,
              I have sent you a PM on an unrelated issue which may be of interest to you and bumped this up while I'm at it. Look in your inbox to read it, second along on the green strip at the top of postings
              Edited By Brian Wood on 10/10/2018 15:10:50
