Gents,
While we all get terribly excited about acids and alkalis and what you add first to whom.
Could I please make 2 points.
We are talking about a weak solution of citric acid. So weak that you can fish parts out if it with the bare hand and carry it over to the sink, and if you have an exposed wound its going to sting a bit no more. Nor is there any problem, even though its better not to, about pouring it into water, or water onto crystals. Even battery strength sulphuric you can put oyur bare hand in – not recomended and get it under fresh water quick, but it can be done., and without any injury.
Second point. The best always the enemy of the good. If you want to neutralise it, salty water. It will work, and a good dose of salty water will do a lot of good, even if its not perfect. Its a lot better than not neutralising it.
Now if we are talking about neutralising IRFNA then it becomes a different matter and you start having to be very careful..
But we are not.
A couple or 4 ounces of citric crystals per gallon is fine. Don’t overheat objects to be pickled to burn on the flux, and wear eye protection when you dunk stuff. When you have finished with it, add water to the citric to dilute it further, add salty or any other alkali water to the dilute citric, and stand back exhausted.
Ditto battery strength sulphuric.
Wow, gents is all I can say about this.
The best is very much the enemy of the good.
Or
Its much better to be approximately right than exactly wrong.
