Posted by Baz on 06/02/2022 17:24:53:
… There used to be two versions of Kasenit, numbers one and two, I don’t know what the difference was, I always used number two, I am sure someone will enlighten me before the day is out.
I found Safety Data Sheets for №1 and №2. №1 was for fine work and is Potassium Ferrocyanide. №2 was for ordinary work and is Sodium Ferrocyanide. There was a №3 too: heated in closed containers so I guess it was dangerous, and withdrawn many years ago. I couldn't find an SDS for it.
Potassium and Sodium Ferrocyanides have similar properties. They're not poisonous, but avoid breathing the hot fumes. Potassium is more expensive than Sodium. Both work by breaking down when heated in contact with Steel to release Carbon and Nitrogen, some of which dissolves into the surface of the steel and hardens it. Carbon and Nitrogen harden in different ways, which is good. Presumably the Potassium salt performs better than Sodium, perhaps because the reaction occurs at a lower temperature.
I found an explanation as to why Kasenit disappeared on the Hobby-Machinist forum with the ring of truth. Ferrocyanides are cheaply made from Hydrogen Cyanide, which is extremely poisonous. Suggested that the source of Ferrocyanides dried up when the chemical industry decided shipping Hydrogen Cyanide was too risky and switched to consuming it at the point of production. Unfortunately, there's not much call for Ferrocyanides, so firms like Kasenit couldn't buy cheap Ferrocyanides or make their own. Things may have changed but I couldn't find a supplier of Technical Grade Sodium Ferrocyanide on the web. High purity Food/Lab Grade is available, but at about £5 for 25g it's far too expensive to use as a hardener.
I don't know what alternatives to Ferrocyanides are used in case hardening compounds, but there's a wide choice – anything with Carbon or Carbon and Nitrogen in it, like charcoal and leather.
