C3 Purchased
C3 Purchased
Home Forums Manual machine tools C3 Purchased
Viewing 24 posts - 26 through 49 (of 49 total)
  • #55268
    Anonymous
      Hi Tigermoth,
      Wow, big models! I got as far as model gliders and some very simple RC power planes back in the days of 27MHz, before I reverted back to flying full size gliders and then full size power. I’ve never flown a Jungmeister, or a Spitfire come to that, although it’s on my list, along with a P51D and a fast military jet. All I need is a lottery win.
      Anonymous
        Hi Ian,
        Forgot to say, one place I’d really like to fly a glider is the NZ Southern Alps; may be one year.
        #55270
        Tigermoth
          @tigermoth
          Right, this posting has moved in another direction altogether!
          I’ve seen a full-size Pawnee acting as a glider tug and thought it had a rustic charm. My model has a scale outline but the colour scheme is very definitely non-scale. It can be flown very slowly, probably the slowest flying aircraft which I own.
          The Moth is in the colours of a 1947 Royal Navy trainer and has a tail skid which is very effective on grass but gets worn away running on concrete or tarmac. From descriptions I’ve read ti’s flying characteristics are very similar to the full size, easy to fly but harder to fly well.
          The Jungmeister is in Swiss colours and is very different to the Moth. It has sharper control responses and does excellent flick manoevres.
          The Spitfire flies beautifully and looks really good on a low pass with the wheels up.Too easy to nose over on landing though.
          I remember the 27  MHz days but since then 35 MHz has come (and been superceded) and in the last few years technology has moved on apace to embrace the mobile phone frequency of 2.4 GHz with the added bonus of computer assistance.
          I have seen Frank Hoose’s website but not the gadgetbuilder one. I’ll have a look after this posting.
          Bob
          #55271
          Tigermoth
            @tigermoth
            I’m a twit. I have the gadgetbuilder website in my favourites
            Bob
            #55310
            Anonymous
              Hi Bob,
              That’s the beauty of the internet, you never know what is going to pop up!
              The Pawnee is a good glider tug, if rather thirsty. We reckon about a (UK) gallon per thousand feet. On the hand it’s built like a brick outhouse and copes very well with wet and muddy airfields in the winter.
              The Tiger Moth is definitely difficult to fly accurately, particularly in turns. Also spins well. Although it wasn’t a requirement to be taught full spins when I did my PPL the CFI’s viewpoint was ‘this aircraft will spin, therefore you will demonstrate three turns of a spin and recovery in each direction’. But then he was ‘old school’ having learnt on Tiger Moths at Cambridge during the war.
              I assume that the 2.4GHz RC sets are part of the ISM band? How do you get on with interference problems?
              #55328
              Tigermoth
                @tigermoth
                Hi Andrew
                My Moth spins both ways and recovers easily, loops nicely after a dive, rolling is poor (first half to inverted OK, hang on for second half with throttle closed), turns definitely need coordinated rudder/aileron control, stall turns both ways with ease.
                No problems with interference at all on 2.4 GHz – receivers are bound to each transmitter.
                Bob
                #55345
                Sub Mandrel
                  @submandrel
                  Sorry to hijack, but I recall my struggles with my first R/C powered job. It kept turing into the ground. I wanted my Dad (the aged P.) to see it, he saw me barely recover from my first turn and said pull back on the elevator as you turn (no ailerons) – it was like he’d worked magic!
                  John Olsen
                    @johnolsen79199
                    I grew up in Masterton  (NZ) in the heydey of the use of Tigermoths for topdressing. As kids we pretty much thought all aeroplanes were Tigermoths, they were always flying over. The glider guys there were using the Tigermoth as a tow plane too, although I was there one day when they first tried using a Pawnee. The difference in the rate of climb was quite noticable, to say the least. Hood Aerodrome was used by the Americans for a squadron of Mustangs during the war, but they were long gone by the time I was born. It is still a favorite place for the glider guys since you can pick up the Norwester wave and fly up and down the length of the country.
                    regards
                    Ian S C
                      @iansc
                      DH 82 A , I’v made a narrow parting tool by jus cutting a radial section , in my case about 5/8″ wide out of the saw blade in cluding the tip in the right place, took about five miniuts, touched the tip on the green grit wheel to make it square (the tips are alternatly angled left and right). The Pawnees here were 235hp Lycoming, but aerial top dressing as its known in NZ started after WW2 with surplus Tigermoths witha hopper In the front cockpit holding 55olb of  super phosphate.At one stage in the 1950s there were over 180 Tigers doing ag work until better AC took over. Exciting times, lots of accidents, lot of the pilots were ex war time, ie Johnny Checketts Flew Spitfires in BOB, and many others, some who were still flying at 70+yrs.Ian S C
                      #55409
                      Anonymous
                        Hi Bob,
                        Sounds like the Tiger Moth model flies very nicely. Do you have the anti spin stakes fitted? I don’t think they were ever fitted to RAF Tigers, but a lot of civilian ones had them. The Tiger Moth (G-ANOO) I flew from Thurleigh (near Bedford) was used primarily as a glider tug. Climb rate was a bit limited, but we did have the advantage of a 10500 foot runway.
                        Most of the Pawnees used as glider tugs in the UK are 235hp too. Nice smooth flat 6 cylinder engine. Actually I’ve been flying our Pawnee today, did three tows and then watched the day degenerate into heavy showers. Still, another 25 minutes in the logbook. I have flown a 260hp Pawnee, and I’ve seen, and had a tow behind, a 160hp Pawnee. I think the 160hp Pawnee has a shorter nose. Despite that you still look under the cowling and wonder where the engine is.
                        Vis-a-vis the RC interference I was curious as to how you got on with all the other users of the ISM bands. I assumed that the receivers are coded (PCM?) to the transmitters, but how do they cope with external interference?
                        #55412
                        Tigermoth
                          @tigermoth
                          My moth does have the anti-spin strakes fitted – I fitted them before I settled on the final colour scheme. I can’t remember whether the original had them or not.
                          The stall is non-existent with my Moth – it slows up, dips it’s nose and starts flying immediately again!
                          Not sure what the 2.4 GHz coding is but this link might have some pointers:
                          Interesting to see the range of engine power available in the Pawnee. I powered mine with a 15 cc 4 stroke engine which is probably at the top end of the power suitable for my size of model (~ 7 feet span). It gave me problems getting the C of G far enough back and I had to resort to ballast in the tail, something which is uncommon in RC models! Broke a wheel hub landing (very slowly) and one wheel ran into a rabbit scrape and the hub collapsed – cheap junk!
                          I’ve now started turning a set of alloy hubs because the wheels supplied had an excellent set of tyres. Half a hub almost made.
                          Hey Stub, do you still fly Rc?
                          Bob
                          #55428
                          Ian S C
                            @iansc
                            Andrew, the wallpaper on my computer is a picture I took earlyer this year of a P-51D ex RNZAF flying at a local air show, one of our local Piper Cub pilots/ farmers turned 70 and his wife and son shouted him a flight(its a twin seat), cost $NZ2000 for about 1/2hr, so near enough to 1000 pounds. Don’t think he came down to earth for a week, and the PA-18 will never be the same again.Ian S C
                            #55433
                            Ian S C
                              @iansc
                              Andrew & Tigermoth, can’t find your profiles, so I posted a photo in the albums that might be of interest, This one’s 12″ : 1 ft and at the time of this photo pushing toward 400mph out of a dive from 5000ft. Ian S C
                              #55436
                              Tigermoth
                                @tigermoth
                                Some nice photos there Ian. I haven’t posted photos on this forum yet – haven’t built anything of real relevance to model engineering yet.
                                Have a look at http://www.buchanaeromodellers.co.uk/ and you’ll see some of our local models.
                                I liked your hot air engingine and am glad to see that your workshop is as tidy as mine!
                                Bob
                                #55445
                                Anonymous
                                  Hi Ian,
                                  Your gentle reminder that I don’t have a profile has shamed me into writing one; as will be apparent I’m not an expert modeller.
                                  #55448
                                  Anonymous
                                    Hi Bob,
                                     Wow, you’re Tiger Moth certainly has all the details! I hope it has working slats too. Ours (G-ANOO) also had a sticky impulse mag. If it didn’t start in a couple of pulls, you opened the cowling, tapped the mag, which freed up the impulse mechanism, and then it would usually start.
                                    I did have a look at your aeromodelling website; interesting. I haven’t been to the exact area, but for a number of years I visited Aboyne (due west of Aberdeen) with various gliders to experience the wave. It’s where I first achieved my Diamond height. Twice in one week, 21000 feet on the Tuesday and 22000 feet on the Thursday.
                                    Thanks also for the RC link. It all sounds pretty sophisticated these days. Certainly spread spectrum techniques should be pretty immune to multipath interference problems and what I assume will be block codes for forward error correction should limit the effects of burst interference.
                                    #55449
                                    Anonymous
                                      Hi Ian,
                                      Thanks for posting the Mustang picture. Where I live, quite close to Cambridge, we see quite a lot of WW2 fighters, particularly Spitfires. We’re pretty close to the Imperial War Museum at Duxford, in clear airspace, and there’s an ex-WW2 airfield just beyond the back gardens of the houses opposite me in case things go pear-shaped, so we get quite a lot of practise and test flights overhead.
                                      I’d certainly pay a thousand pounds to have a go in a P51D. It’s definitely on my list of things to do. However, I think it’s rather difficult in the UK due to some daft CAA rules.
                                      #55450
                                      Ian S C
                                        @iansc
                                        A the same fly in Harvard, ex South African air force $NZ200, DC-3 $NZ80.Ian S C
                                        #55461
                                        Tigermoth
                                          @tigermoth
                                          Hi Andrew
                                          My Tiggie is probably my favourite aircraft – I’ve hadit for about 8 years now.
                                          I didn’t make the slats work for 2 reasons. They had a minimal effect on the stalling speed of the full size and the complication in making both work reliably on a model. I didn’t fancy the thought of only one of them popping out. I did think of putting slats onto a separate channel but thought the effort wasn’t justified.
                                          Bob
                                          #55489
                                          Ian S C
                                            @iansc
                                            I have seen them (slots) full size left fixed in a open possition, don’t know what ill effect that had. Ian S C
                                            #55516
                                            Tigermoth
                                              @tigermoth
                                              I thought they were commonly left closed; when active, I believe they reduced the stall speed by about 3 mph.
                                              Bob
                                              #55531
                                              Anonymous
                                                Hi Bob,
                                                You certainly seem to have an intimate knowledge of Tiger Moths; one might almost suspect that you flew the full size aircraft?
                                                Accrding to my pilots notes the slats make exactly 3mph difference in stalling speed; 48mph down to 45mph. Also according to the notes the slats should be locked during taxying and before aerobatics and spinning. Presumably at other times they were left free. I can’t remember exactly what we used to do with them. I suspect they didn’t change much either way.
                                                #55535
                                                Tigermoth
                                                  @tigermoth
                                                  The Tiger Moth has been covered in many books and articles but I have never been in the full size. I nearly came close when visiting Australia about 8 years ago but the Moth available for flights at Caboolture was grounded for maintenance. I got a real close up look at the Moth then and also at a P51 which was in for a respray for taking part in a film – cant remember which film though.
                                                  Bob
                                                  #55544
                                                  Ian S C
                                                    @iansc
                                                    Bob it could have been the TV series “The Pacific” it was on tv down this end this year, about the Pacific WW2. We actually have a company down south that specializes in rebuilding DH aircraft, them that work there are known as Moth Doctors. Ian S C
