Brian’s 1″ Minnie Traction Engine
Home Forums Traction engines Brian’s 1″ Minnie Traction Engine
Viewing 25 posts - 151 through 175 (of 341 total)
  • #274335
    Brian Abbott
      @brianabbott67793
      Hello all, Merry Christmas,
      Jason / Richard
      After some more advise if possible, progressing ok with the tender but not had as much time over Christmas as i would have liked, The book says to solder the tender bush ( for the Tender water union ) last, i guess using solf solder.
      Is this the way you did yours, my thoughts were that it may be better to silver solder this bush into place then rivet and soft solder the assembly up as instructed,
      Thanks for any help as always.
      Edited By Brian Abbott on 29/12/2016 23:34:55
        I can't see that it makes much difference on such a small bush, on my 2" fowler you need access to the inside of teh tender for some of the riviting so any extar hole to look through or poke an extended rivit snap into is handy but not really needed on the minnie. Just mind you don't kink teh brass tender back/base when silver soldering.
        #275219
        Richard S2
          @richards2
          I Soft Soldered the bushing(s) on both the original Brass one and the revised Steel Brass lined version. Plenty strong enough. Just make it a good fit and sweat it in both sides when you're doing the joints.
          #275418
          Brian Abbott
            @brianabbott67793
            Thanks both…again.
            I am going to take your advice and soft solder the bush in, i was worried about distorting the brass plate if i silver soldered it.
            #278800
            Brian Abbott
              @brianabbott67793
              Hello all.
              I am nearly at the point where i can solder the tender, i have tinned the edges, and am in the process of riveting the parts together,
              Due to everything having being riveted i am no longer able to clean any of the joints, will this be a problem or is this the point of using the flux ?
              Should i have cleaned, riveted and soldered all in one sitting as quickly as possible ?
              Thanks for any advice.
              #278819
                Should be OK provided you apply some flux to teh edges of teh joints before you start heating it up, the flux will melt and flow into teh tinned joints. Probably need to run a bit of extra solder hear and there, the cored electrical solder is quite good for that.
                #279056
                Brian Abbott
                  @brianabbott67793
                  Thanks Jason.
                  #281746
                  Brian Abbott
                    @brianabbott67793
                    Afternoon all.
                    I have inadvertently made the draw bar for my minnie out of stainless.
                    When i finally paint the tender, do you think this would take the paint ok ?
                    Thanks.
                    #281755
                      Probably stick better to that than it will the brass!!
                      Just give the lot a coat of etch primer and then your colour on top of that, you will need the etch for the brass anyway.
                      J
                      #282165
                      Brian Abbott
                        @brianabbott67793
                        Etch primer..Ok..
                        Jason, when you get a chance, would you mind posting a picture of the tender on your Minnie, Ideally around where the draw strap wraps around into the draw bar, viewed from the back
                        Thanks Jason.
                        Edited By Brian Abbott on 03/02/2017 13:16:43
                        #282173
                          Will do.
                          Better dust it firstblush
                          #282188
                            Brian Abbott
                              @brianabbott67793
                              Thanks Jason,
                              just wanted so see how you had bent the draw strap round the corner into the draw bar.
                              i've done mine the same.
                              Thanks again
                              #286463
                              Brian Abbott
                                @brianabbott67793
                                Hello..
                                This is a sketch of the by pass valve on the Minnie i am building.
                                Unsure of the angle of the pipe cones, in the past i have just used the drill angle which seems to work ok, is this right ?
                                Thanks.
                                #286469
                                  Should be 60degree inclusive, easily done with a centre drill and will then match off the shelf nipples/ferrules
                                  #286630
                                  Brian Abbott
                                    @brianabbott67793
                                    Thanks Jason.
                                    #286672
                                    Brian Abbott
                                      @brianabbott67793
                                      Hello Jason,
                                      Can you remember what diameter pipe you ran from the by pass valve, was it 1/8" OD ?
                                      #286674
                                        No can't remember.
                                        But just had a look and its all plumbed in 1/8"
                                        #286675
                                        Brian Abbott
                                          @brianabbott67793
                                          Ok, thanks Jason.
                                          #292606
                                          Brian Abbott
                                            @brianabbott67793
                                            Hello again.
                                            I am in the process of machining the cylinder on my minnie.
                                            I spent the day yesterday boring the radius on the saddle ensuring it was a good fit against an off cut of the boiler tube.
                                            Now complete and tried against the boiler there is the slightest rock, I can only guess that the boiler tube has distorted slightly.
                                            The gap is no more than a paper thickness in on corner so not much.
                                            Should I try and file them in together or will the gasket sort things out.
                                            Thanks.
                                            #292621
                                              You may find that as you tighten the bolts the boiler shell will pull back into shape if its is only a small rocking that you are getting.
                                              #292822
                                              Brian Abbott
                                                @brianabbott67793
                                                Thanks Jason, glad you said that.
                                                Sorry for not getting back to you sooner,
                                                #294098
                                                Brian Abbott
                                                  @brianabbott67793
                                                  Hello All..
                                                  Can anyone tell me what the pocket is for on the underside of the Minnie cylinder block ?
                                                  The book calls it a sort of steam dome and according to google this is to prevent water entering the cylinder, is this correct ?
                                                  Thanks.
                                                  Edited By Brian Abbott on 19/04/2017 16:51:27
                                                  #294107
                                                    You will find it on most traction engines, it does indeed act a bit like a steam dome allowing steam to be drawn off higher above the top of the boiler barrel and therefor the water level which reduces the risk of priming.
                                                    #294217
                                                    Brian Abbott
                                                      @brianabbott67793
                                                      Thanks Jason.
                                                      One last thing ( for now anyway )
                                                      The drawing calls for the bore to be. 0.625" and also for the piston to be 0.625"
                                                      Does the piston need to be a really good slide fit or should i have a little clearance ?
                                                      I have not noticed in the book what size o rings to order, i will have another look.
                                                      Thanks.
                                                    Home Forums Traction engines Topics
