Brian’s 1″ Minnie Traction Engine
Home Forums Traction engines Brian’s 1″ Minnie Traction Engine
Viewing 16 posts - 326 through 341 (of 341 total)
  • #776979
    Brian Abbott
      @brianabbott67793
      Thank you both for the reply’s
      IMG_7086
      Plasma
        @plasma
        Brian,
        I’m new to this thread but I think that looks amazing my friend!
        The piping to the tender looks fine to me the way you did it.
        Things takes as long as they take, I know Django is concerned about having enough time to complete a mini.  But if you have to put in full shifts every day the hobby will soon start to feel like a job.
        I’m building a kit model which could be completed from box to unpainted built in 24 hours. But I’m modifying and making new parts so it’s going to take me at least a couple of years of hobby tinkering to finish it off.
        You’re doing a fantastic job, can’t wait to see her finished.
        Mick.
        #777067
        Brian Abbott
          @brianabbott67793
          Thank you Mick
          Paper template made for the cladding, need to transfer onto the brass.
          IMG_7094
          IMG_7095
          #779768
          Brian Abbott
            @brianabbott67793
            Wondering if you could offer me any help regarding the riveting on the wheels?
            I am just starting on the fronts but the problem i am having is this,
            When i originally built the wheels, each spoke was drilled 1/16 for the rivet, the second hole was then opened up to suit a 10ba screw.
            The problem i am now having is the oversized hole won’t rivet very well, i think the rivet is just swelling in the oversized hole.
            Wondering if anyone has any tricks ?
            I did think maybe fill the hole with solder and re drill the correct size.
            Thank you
            #779773
              You might just have to start with a longer rivit so that there is enough material to fill the larger hole and still leave enough to form a head.
              This may require the making of an intermedial rivit snap so you can start to form it without the shank bending over, think of the shape like an upturned bucket.
              I don’t recall enlarging any holes on the Minnie or the Fowler’s tender, I think that although a screw could not be pushed into  a1/16″ hole it could be screwed in and once done a few times the screw lost a bit off the crests.
              #779780
              Brian Abbott
                @brianabbott67793
                Hi Jason
                I think it was down to my own inexperience, i will try what you suggested as this would swell the rivet filling the hole without it bending,
                Thank you
                #781946
                Brian Abbott
                  @brianabbott67793
                  Hello Jason,
                  Could i ask how you clamped the boiler banding on your engine?
                  Did you drill and bend the ends ?
                  Thanks
                  #781947
                    looks like I soldered a couple of 1/8″ square blocks to the ends of the banding.
                    banding
                    #782043
                    Brian Abbott
                      @brianabbott67793
                      Thanks Jason,
                      I have made some small angle brackets but i am really not happy with them, will follow your example i think.
                      Thanks again.
                      IMG_7154
                      #799096
                      Brian Abbott
                        @brianabbott67793
                        Hello All,
                        Anyone any tips on how to make the ratchet wheel on the Minnie Lubricator ?
                        Thank you.
                        Capture
                        #799097
                          Make a small flycutter/single point tool with an acute end and proceed as if you were gear cutting.
                          ratchet
                          #799103
                          bernard towers
                            @bernardtowers37738
                            Can also be done with a standard end mill, just change the shape of the pawl
                            #799107
                            Andy Stopford
                              @andystopford50521
                              I think I used a dovetail cutter on the centre line
                              #799112
                              Clive Brown 1
                                @clivebrown1
                                Here’s my 40t Allchin wheel, 1/2″ dia. Cut by grinding an angle on a 1/4″ square hss toolbit which is held in the lathe toolpost and using the carriage as a shaper. The lathe spindle was indexed using a changewheel. Quick and done in one chuck setting.
                                Ratchet
                                #799125
                                Andy Stopford
                                  @andystopford50521
                                  Having had a look at it, I think I set the edge of the dovetail cutter a bit below the wheel centre line to give a slightly hooked effect to the teeth.
                                  #799854
                                  Brian Abbott
                                    @brianabbott67793
                                    Thank you everyone for your help and advice, and sorry for the slow reply.
                                  Home Forums Traction engines Topics
