Thanks to Andydextrous for the offer of a copy of the manual. I've had the machine for more than a year now and have made a few modifications to it to make it more use as a drill/cutter grinder rather than a dresser for lathe tools.
I made a new mount to make the motor spindle take a cup grinding wheel rather than the original diamond dressing wheel ( the diamond wheel was intended for dressing lathe tools and took too long to take a chip out of a damaged drill or cutter). I mounted the wheel guard further forwards to make it cover the deeper wheel.
To cope with the length of drills I moved the motor back (by approx 150mm) by adding a piece of 120 x 10mm plate between the mount and the motor.
To hold drills and cutters I bought an MT3 sleeve with a parallel outer and then bored a length of 50mm square bar and a length of 50mm hex bar to suit the sleeve. The square and hex have a big washer on one end to provide a register on the side of the tiplap "table" and a grub screw to hold the sleeve in the correct orientation for grinding (to suit the tang of the drill being ground).
I can now use an MT3 chuck, or an MT3 collet chuck to hold ordinary drills and cutters or taper shank drills can be held directly or via reducing sleeves
The orientation of the drill/cutter can be set using the grub screw and then turning the square or hex bar each cutting face can be ground in turn.
I thought that I would have to make a clamp system to hold the parts being ground but I soon found that I could simply hold the square/hex in place by hand as the cutter is being ground.
I hope this helps anyone trying to modify/use one of these machines for cutters/drills. I'll take some photos if anyone needs or wants them.
Martin
